Question about Kenmore HE2 Plus Front Load Washer
Washer has a F-30. What does this mean? - Kenmore HE2 Plus Front Load Washer
  • Kenmore Master
  • 8,220 Answers
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
What does E6 mean on a baumatic bwm70
E6 on the bwm70 means that there is a water sensor level error. You can try resetting the error code to see if it comes back on by pressing and holding the the power on, start/stop button, or unplug the washer, wait 30 seconds and try again. If you still get the E6 code, your washer will need to be serviced
Jun 18, 2014 | Washing Machines
Error code F-21
this code means a long drain meaning if it takes over 8 minutes to drain it will show this code and possibly "suds" code too,first try unplugging the washer for 30 minutes as this clears the central control unit if this is the case,if this doesn't help then check the drain pump located below the washer tub for any obstructions such as coins etc.if this isn't the case make sure drain pump is operating and not noisy,if it is then the drain pump needs replacing
Oct 20, 2012 | Kenmore HE2 Plus Front Load Washer
What does the F30 code mean on my Maytag washer?
I just spoke to a repairman who claims he's been working on Maytag washers for twenty years and has never heard of an F-30 error code. He says all Maytag error codes are four digits, and this isn't a real thing. Like I'm lying. While he's saying this, I'm watching the F-30 code flash on my machine. My God, you can't find anybody who knows how to fix anything any more...
Sep 01, 2011 | Maytag MAH6700AWW Neptune Front-Load...
May tag 5000. f35 what does that mean
"F35" means Analog Pressure Sensor Failure
If the washer does not accept inputs from the control panel, follow the Hard Reset steps below to reset the control:
Unplug or turn the circuit breaker off for 30 seconds.
Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
Press the Pause / Cancel / Stop button twice to clear the display.
Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Note: If the Hard Reset does not work, there may be an internal failure with the washer, that requires service.
Hope this helps.
Jul 09, 2011 | Maytag Washing Machines
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Duet washer code f 33? What does it mean?
the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Error code 30?
It means the drum is overfilled with water. . Select the drain and spin cycle to empty the washer. Then start over. If this doesn't work, you will need a repairman.
Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Lg washer
From the manual - LE is overload in motor. Restart the cycle after 30 minutes. If LE is not released, call for service.
Jun 04, 2008 | LG WM2277H Stainless Steel Front Load...
Kenmore HE2 Plus Front Load Washer Logo
158 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
