Question about Triton My Weigh T2 300 - Digital Pocket Scale / Jewelry Scales
My problem triton t2 is : oue2 or unse (and i have change the piles ?!) thanks for your answers
Tip
Access to the NAS-T2 from Linux
Quick tip: when accessing the NAS-T2 from Linux, mount any NAS-T2 shares using smbfs, not cifs.
More detail: This tip presumes you're familiar with mounting filesystems in Linux and are trying to mount an NAS-T2 share in Linux. The older smbfs filesystem type for mounting Windows shares is deprecated in favor of the newer cifs filesystem type. However, the NAS-T2 is built on some older flavor of Windows and behaves very oddly when mounted as a cifs filesystem. Changing back to the older smbfs filesystem type solved all my problems.
on Jan 13, 2008 | Fastora 2 Bays Network Attach Storage...
How to remove the tray on a triton t2 300g digital scale
Google a triton t2 300g digital scale manual and follow the directions.
Mar 10, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My trilogy alrm lock t2 dl2700 was installed yesterday and i tried to change the security code but something happened i did not know what did i enter. now can some one help me what should i do to reset it?
This is the website for Alarm Lock, the manufacturer:
http://www.alarmlock.com/#
Scroll down to find the T2 programming instructions.
From here you can go to Tech support or contact them--I'm sure you'll get your best answer there.
Feb 26, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
How to update for SD reader
You don't.
You have to a seperate HC reader.
Had same problem.
Apr 04, 2010 | Panasonic Toughbook T2 Notebook
Setting watch
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
Hope this helps.
Nov 12, 2007 | Columbia All Sport Digital watch
Triton My Weigh  T2 300 - Digital Pocket Scale / Jewelry Scales Logo
515 people viewed this question
Top Triton Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Triton Health and Beauty Expert? Answer questions, earn points and help others
