Question about Microsoft Windows Server 2003 Enterprise Edition x64 for PC
I am using XP.. net modem working case if take a long time for System shutdown.. if put off modem immiditly shutdown. how to shutdown if working modem.
    Brigadier General:
  • 10,406 Answers
Windows Server tries to "gracefully" shutdown.
This implies that any "active" network-connections that use the modem will be signalled to "properly" close. This may take a while, waiting for the "other" end of the connection to respond.
However, if you have no active network-connection, then Windows does not need to "wait" for the "other" end of the connection to respond -- it can immediately close the "severed" connection.
Posted on Sep 13, 2010
I used to connect to the net via PC using my LG ke970 as modem. But, suddenly it stopped working one day. Says error 777 on the PC. Modem is out of order. But,this problem is only with Windows 7. Why? How...
I used to connect to the net via PC using my LG GX 300 as modem.
But, suddenly it stopped working one day. Says error 777 on the PC (windows XP). Modem is out of order. And also LG PC suite cannot run. Why? How can i solve this?
Feb 11, 2011 | LG Shine KE970 Cellular Phone
My computer restarts when i turn off the computer
Most Win XP shutdown problems reported thus far have been that it reboots when shutdown is attempted. This may be a global symptom emerging from several distinct causes, because, by default, XP executes an automatic restart in the event of a system failure. Therefore, more or less anything compromising the operating system during the shutdown process could force this reboot.
Disabling the “restart on system failure” feature may permit the exact cause to be isolated: Right-click on My Computer, click Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” uncheck the box in front of “Automatically restart.”
Here are some of the things that may have produced this reboot-instead-of-shutdown symptom. Please refer below and perform the steps which are appropriate to your situation:
  • By now, the Roxio/Adeptec Easy CD / Direct CD software is well documented as being the major cause of this undesirable shutdown behavior. SOLUTION: Roxio has released new drivers (here) to solve this problem in both the Platinum and Basic editions of Easy CD Creator 5. As expected, at least half of the Win XP shutdown problems went away with the release of these patches.
    One warning about this patch comes from correspondent Bert Smith: Be sure to read the directions! “Roxio Easy CD Creator Platinum 5.0 can be a real hassle to get working under Win XP,” Bert wrote, “and there is the risk of your computer not booting if you blindly go ahead and install it without first consulting the Roxio Web site.” Bert also mentioned that Roxio’s “Take Two” backup program (normally part of Easy CD Creator 5 Platinum) is uninstalled when the Roxio patch is applied.
    • Direct CD. Many Easy CD users (but not all) found that installing Easy CD 5.0 does not cause the shutdown problem, provided they do not install the Direct CD component.
    • UDFRINST. Several people solved this reboot-on-shutdown problem by deleting the UDFRINST file. This file is part of the Roxio CD-RW software for systems not using Direct CD.
    • CDRALW2K.SYS. Correspondent Larry Blumette identified the CDRALW2K.SYS file (version 1.0.0.1048) as the Roxio file causing his shutdown problems and error conditions. When he deleted or renamed this one file, his problems went away. (Of course, you lose your CD functionality that way, too.)
    • Video Pack 5. Roxio’s Video Pack 5 causes the same problem because it contains includes the main parts of Easy CD 5. SOLUTION: Uninstall Video Pack 5 and also delete CDRALW2K.SYS (Tip from Christian Männchen). However, this solution may also have the side-effect of disabling access to your CD or DVD drive. SOLUTION TO THE SIDE-EFFECT: Apply one of the repair methods in MSKB Article 270008, Code 31 Messages Occur After Removing Adaptec Easy CD Creator 4.02c in Windows 2000 (Tip from Peter Kingsley).
  • Whether or not APM is enabled makes a difference — but the effect could go two ways. Some users report that XP reboots on shutdown if APM is enabled, but shuts Windows down just fine if APM is disabled. Other users report exactly the opposite behavior. According to Jack Dunne, this is similar to a known Windows 2000 problem. The issue seems related to the computer’s specific hardware or BIOS — so, as with all NT operating systems, stick to the Hardware Compatibility List where possible.
  • USB Connections As can be seen from remarks in the Misc. Hardware Issues section below, several different USB-related issues can impact shutdown. One of the most concrete examples was a “reboot on shutdown” problem contributed by correspondent Rick Bross. If his several USB devices (PDA cradle, flash card reader, etc) were plugged into the motherboard’s USB ports, his computer would reboot on an attempted shutdown; but when, instead, he plugged them into an external USB 2.0 hub, shutdown went just fine. (This was with Win XP Professional SP1 on a Supermicro X5DAE dual Xeon motherboard. The same devices plugged into an Asus A7M-266D dual AMD 2000MP system on the same OS worked without problem.)
  • “Wake on” power settings Power-management settings that have the computer “wake” on LAN, USB, modem, or (for that matter) probably anything else may also trigger a restart after shutdown. Correspondent Simon Wei provided this tip after a friend of his found an old old Logitech USB mouse would trigger “wake on USB” after every Windows shutdown. Their solution was to remove that particular mouse and all worked fine. The principle is much more far-reaching than this one example.
  • Hidden “wake on” power settings If you have an Ethernet card integrated into your motherboard, you may have hidden “wake on” settings that are harder to find. Site visitor Jim Porter found that his Asus P5GDC-V Deluxe motherboard had a “wake on” setting in Device Manager | Properties | Advanced rather than in the BIOS or Power Management settings. (The Asus P5AD2 and P5GD2 boards have this also.)
  • Y-SB3 Logitech Internet Keyboard can also cause this problem. If you use it as a simple generic keyboard, there’s no problem; but, if you install the Key Commander software that drives the special Internet functions, Win XP will restart instead of shut down. Unfortunately, Logitech has decided that they will not be updating this driver for this keyboard. (Tip from Jan K. Haak.)
  • Logitech MouseWare 8.6. Windows reboots when shutdown is attempted. The software caused a BSOD with KBDCLASS.SYS. Removing the software solved the BSOD the problem. (Tip from Pablo Cheng.) MouseWare 9.0 and 9.1 also have been linked to reboot-instead-of-shutdown in Win XP. Removing the software resolves the problem. (Tip from Aswin Kindts, Greg Williams, and others)
  • Webstar DPX USB cable modem. In the one case known to me, the problem was solved by switching the modem’s connector from the USB 1.1 port on the motherboard to the USB 2.0 PCI card. (The modem was provided by Telewest Broadband, manufactured by Scientific Atlanta.) (Tip from Ann L. Goonan.)
Jul 03, 2010 | Computers & Internet
Hardware shutdown
Terrible storm, did that include lightning ?
If you re-installed windows, did you re-install the correct Acer drivers ?
Turn off the computer and take the battery out of the laptop over night
and then put it back together and 10 to 20% of the time, it re - boots and un-freezes the modem...
The modem has a small brain that is why u unplug the battery over night to try to get it working correctly again....
Also check for Acer drivers for that modem.....
If it still does not work then you will have to replace the modem with a usb dongal type modem like US Robotics for about 25 to 35 plus shipping....
http://www.ecrater.com/product.php?pid=555167
US Robotics 56K modem w Dongle cable pcmcia USR CC1560 I hope this helped you
Thank you Techlahj
Aug 21, 2009 | Acer TravelMate 6493-6495 Notebook
I don't have driver usb hfs modem, how toget the driver ????
1. Where can I get drivers for my Rockwell/Conexant HCF or HSF modem for Windows XP, or I am having difficulty installing my modem in Windows XP?
Conexant has worked with Microsoft to ensure that many PCI modems are supported using a generic data/fax driver that is available on the XP distribution CD, therefore in the majority of cases your modem should automatically be detected and the generic driver correctly installed. Run the List Modem application (listmodem_app.zip) found on the Modem Driver Assistance page to find out if your modem is supported in the inbuild driver on WinXP. If the answer to "WinXp Inbuild Support" is yes, then your modem will work after upgrading to WinXP even when you run the compatibility test before upgrading and you get a warning. However the XP distribution CD does not have drivers for Conexant USB modems or modems that interface to the PC using the AC-Link bus. The AC-Link bus is primarily used in notebook PC's and some desktop PC's. In these cases it is necessary to download the correct driver from the manufacturer before upgrading to XP. If you get the message shown below and you have a notebook PC use the links below to obtain XP drivers.
Example XP Error Message: xperror.gifIf you do not have one of these PC's it means that the current driver that you are using in your previous operating system is not compatible with Windows XP, however if you have a PCI modem it is very likely that your modem will be supported by the driver available on the distribution CD and will work when you upgrade to Windows XP, and you should proceed with the upgrade. Links to OEM Drivers: carrot.gifSony VAIO Systems
carrot.gifGateway Systems
carrot.gifHP
carrot.gifDell
carrot.gifToshiba
carrot.gifLegend
carrot.gifAcer
carrot.gifNEC
carrot.gifFujitsu
carrot.gifTwinHead
carrot.gifMaxData
Jul 27, 2009 | Computers & Internet
How to schedule system shutdown in windows xp
Go to Start >> Run type CMD and click Ok
in the command window
just use the AT command:
AT 9:00 SHUTDOWN -f
the schedule service must be running while using the AT command.
But normally it word well
Dec 30, 2008 | Microsoft Windows XP Professional
Svchost error with zyxel p 600 series
your operating system is corrupted..........
Dec 05, 2008 | Zyxel Prestige 841 (91-004-226010) Modem
No sound in aspire 5315
- I guess you downgraded your system to windows xp, If that the case you have to check if the system has an internal modem .If so, please download the driver for that PCI modem.
- I have already checked the modem that was already install on your system(V.92 56Kbps* data/fax modem,)
- You have to download the windows xp driver for this modem. or download chipset driver for windows xp
Oct 08, 2008 | Acer Aspire 5315 Notebook
Vista PC connecting to DSL-504T modem/router
first make sure that model router you have supports vista. i can help you more if i had alittle more info on your router.
Jun 01, 2008 | Compaq Presario 5000 PC Desktop
Dynex m300 modem problems on xp
rich, Below is the link for the newset drivers for you modem. http://www.dynexproducts.com/t-drivers.aspx Make sure your machine is up to date with microsoft. Have you checked for viruses and spyware? Is the machine running hot? It is sounding flakey(like a bad unit). You should not have to do a system restore because of a modem unless it just really "hosed" your system and if that was the case,then that would be the last time I would use that modem. Let me know what happens Good Luck, Tim
Feb 13, 2007 | Dynex (DX-M300) Modem
Microsoft Windows Server 2003 Enterprise Edition x64 for PC Logo
44 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
