Question about Samsung Televison & Video
Flickering white cloudy screen. Can still make out picture barely.
    Brigadier General:
  • 6,966 Answers
Based on your general description, it could be:
1. loose connection or cold solder on any of the connectors and/or boards specially those related to power;
2. heat related - at some point, the heat generated inside the unit could cause a component failure or worsen a cold solder/loose connection;
3. a component is about to fail - on most Samsung projection TVs, this would be the DM board. Exhibited symptoms would be screen flickers (white flashes) and in some instances after about a minute the screen gragually turns very very bright (almost white) from the bottom of the screen to the top.
Any of the above would require familiarity with electronic circuitry and components, use of a DVM and a soldering iron as well as access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable venturing into a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 22, 2008
Tv problem troubleshooting screen all white no picture
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | LG Televison & Video
Laptop screen white and cloudy
From your description I would expect that the LCD panel has shorted or gone open. Either way the panel needs to be replaced. Depending on the age of the laptop you may be better off getting another laptop, new or used, and just swapping out the hard drive to your drive. If you decide o do this be sure that the laptop you buy is compatible to your old drive.
Jun 08, 2017 | Computers & Internet
Toshiba Mini NB205-N230 screen Flickers and becomes Unusable
Either the cable that runs from the screen tot he motherboard is loose/broken or your video chipset on the motherboard has dry solder joints.
Mar 10, 2012 | Toshiba Mini NB205-N230 N325BL WH BN PK 10...
Picture flickering and faded on left had side of the screen
if rebooting the monitor would do no good, try to get a spare monitor cable if the same flickering issue took effect. If it is so, then call your pc provider to repair your monitor..
Nov 26, 2011 | Philips 47 in. LCD HDTV
Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Toshiba Laptop with flickering screen
its a faulty screen. i would call samsung or go to their website and have it fixed.
Jul 25, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Picture issues
your green tube is trying to go out
Oct 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Cloudy white pictures
Cloudy images are usually a result of ccd gone bad. Try power reset, maybe it helps..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
Televison & Video Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
