Question about Sony Video Cameras
I have a ..tvr608 hi 8 camera..the code c:31:22..i tried removing tape and letting sit open for 24 hrs to dry (per manual) nothing..any suggestions??seems like " tape drive " is slipping..if possible..making humming sound and tape has lines in it when playing
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error C 31:22 is caused due to bad Gear assembly, to resolve this issue with the battery &cassette removed try whacking the camera sideways, if after doing this still the issue is not resolved then you’ll have to get the Gear assembly replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 13, 2010
  • 10,594 Answers
Previous answer is user level reply, I'm expecting Expert Level solution from expert at Fixya.com
C:31:22 is an error code that shows problem with Take-Up Reel signal in tape mechanism. Whacking the camera sideways might solve camera problem temporarily but proper fix needs expertise of experienced camera technician.
Ice maker on whirlpool quit working .
If it's like my Samsung, there is a reset micro switch button in front of the box containing the ice cube tray. Press it and the machine resets, the ice cube tray rotates, dumping the cubes. It then rights itself and fills with water. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Full glass of water spilled on my iTouch keyboard. Have tried a fan on it for over 24 hrs and still nothing. Can you help?
Unfortunately some things don't mix (like electronics and water). You can try to dry it out more, let it sit upside down. Make sure you take the batteries out if you haven't already. If that doesn't work you will most likely need to replace it.
Apr 26, 2011 | Logitech Cordless iTouch Keyboard/Cordless...
Hi, i just bough an automatic watch with a Sellita sw200, is 2 (Two) seconds to fast in 27 - 30 hrs consider ok? I fully hand winded and let it sit for that period of time it is stil functioning after the...
This deviation is perfectly acceptable. Even a certified chronometer may deviate -4 to +6 seconds per 24 hour period so you should be pleased with +2 seconds.
It is highly unlikely that any exchange will fair better. Also, the deviation will depend on the position of the watch. So, if you wear it, you will know its average deviation much better.
Dec 14, 2009 | Ebel 1911 1087221 wristwatch
Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Thanks
Kate
Sep 07, 2008 | Sharp Viewcam VL-AH151U Camcorder
E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Mar 27, 2008 | JVC Cybercam GR-DVL805 Mini DV Digital...
"remove tape"
I've had my GL-2 for about 3 years, and just recently started experiencing this problem. It happens when I flip the power saver switch off, then back on again. I've found that removing and reinstalling the battery lets me continue without ejecting and inserting the tape. I also just replaced the watch battery but I'm still getting the "eject" message when I use the power saver switch. I'm not looking forward to spending hundreds of dollars, but it "is" quite annoying.
Mar 04, 2008 | Canon GL2 Mini DV Digital Camcorder
Code 32:11 will not eject tape sony tvr67
The mechanism got stuck. Open the cassette compartment screws and apply external DC to the Power input and eject the tape. If this is not possible refer to a skilled technician. If you need the service manuals and mechanism for replacement write to us.
Dec 07, 2006 | Sony Handycam CCD-TRV67 Camcorder
Video Cameras Logo
751 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
