Question about Refrigerators
My KitchenAid refrigerator has stopped making ice.
  • 1,040 Answers
I would first check to see if there is an ice cube or two stuck in the ice maker.
Then make sure that the frig is not on top of the water line, blocking water from getting through the line, (especially if you have moved the frig recently).
If neither one of those suggestions are it, then make sure that your water filter is not clogged; if you have one connected to the line.
And if none of these help,then make sure that the shut-off valve is turned on.
Jim
Posted on Sep 13, 2010
  • Jim Parker
    Jim Parker Sep 13, 2010
    Thanks for the rating. I'm glad I could hep! So what was the problem.
    If you should ever have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice Maker will not stop making ice
On Your KitchenAid Superba they use an electric eye receiver board part# 4389102. You might want to try cleaning your icebin and the electric eye to see if that works first.http://www.on-timeappliance.com/refrigeratorrepair.html
Mar 27, 2012 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 25in KSRJ25CNST00 icemaker trouble. The LED light on side of freezer is blinking twice with a delay and repeats same sequence. No ice is making. Any suggestions on what to look for?
Try the reset button on the control panel. If that doesn't work, then try unpluging the refrigerator.
Also, make sure that ice tray shut off arm isn't in the up position. It should be in the unlock position one notch below the off position. This arm is used by the refrigerator from over filling the ice cube holding tray. Once the ice fills the tray. The ice in the bend will push up on the arm which
initiate the ice maker to stop making ice. As soon as you start using the ice in the bend and the arm falls below the off position. The ice maker will start making ice. GB....stewbison
Sep 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
I have a ksra25ilss01 model side by side kitchenaid ref that will not stop making ice. It keeps overflowing the door tray.
The wire in the ice machine part is being heald down by ice I would guess, try and mess with it empty it all out of ice and let it start over again.
Jun 24, 2011 | KitchenAid KSRA25ILSS Side by Side...
Kitchenaid refrigeratorice make no water
When the ice maker stops to fill with water ,check if the solenoid (dual valve) gets power (110 volts) ,if it does and won't open you have to replace it ,but if it doesn't get any power ,the problem is the ice maker itself.
Sep 04, 2009 | Refrigerators
My ice maker has stopped making ice. I have Kitchenaid Architect II KSRS25FTBL.Water dispenser is working fine. Ice maker is turned on.
Could be the solenoid valve. It is usually located where the water line connects to the frig. The valve may have trash in it.
Feb 21, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid built in refrigerator controls are beeping
Might be an ice cube stuck in the ejector. Hit it with a hair dryer.
Feb 14, 2009 | KitchenAid KSSC48QMS Side by Side...
Kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Sep 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice maker stopped working
the oil in the compressor has pumped up to the top hence the ice is not formed the lead valve in the compressor is not working properly so change the lead valve and you could make ice as before
Jul 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
