Question about HP z555 (PS501AA) PC Desktop
Hp z555 HI I HAVE A HP Z555 I HAVE PROBLEMS WITH SOMETIMES IT POWERS UP JUST FINE AND THE OPERATING SYS STARTS JUST FINE THAN SOMETIMES I TURN IT ON AND THE SCREEN STAYS BLACK THE CPU FAN SEAMS TO OPERATE FASTER AT LEAST IT MAKES SOM LOUDER NOISE AND THE START PUSH BUTTON STAYS ORANGE CAN YOU HELP
  • Anonymous Dec 12, 2008
    me too. and tonight, instead of the power button turning orange, it flashed blue while the screen stayed black. hmmm.
  • 263 Answers
SOURCE: presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Posted on Jan 05, 2008
dutchman05
  • 487 Answers
SOURCE: hp is making a loud noise after being on for awhile
It is most likely the processor fan which is getting busted or dirty.
Open the machine after having it unplugged and blow it all dut in machine and from both fans. Clean the fans with a soft brush and see if that works. Otherwise you will have to replace it. But normally it is just dirt
Posted on Apr 26, 2008
13thLegion
  • 8 Answers
SOURCE: HP Desktop power up problem
Bad ram probably, units do that all the time at my job. Most of the time, it is the power supply that does not have enough power to invest into all hardware that makes your pc. even if you had a 400watts power supply, the next time you are buying a power supply you should do some kind of upgrade. 600 watts or more. If you have a high end graphics card then you are indeed in need of a new power supply. also check your cpu, its fan, check if it still seated properly, if there still paste on top of it to hel cooling it down, and protect it from statics. if you added new hardware, remove them and keep checking if it is working. To do manual diags, you need to take the unit apart. I would start by removing rams first, and check ram one by one, then hdd, then disconnect other components until i find the actual part. I am sure it is your powersupply, worst case scenario is you mobo is gone.(but it powers up and shutdown after all so let us hope you don't have a dead motherboard." and remove the dust please, dusty units do not run properly. Neim Le Legionaire.
Posted on Oct 19, 2008
SOURCE: Hav a pavilion a510n HP
I had a similar problem. Moved a 4-year-old desktop. Got the flashing light and no start. Quick fix is to unplug unit, open up case and unplug the large power connector on the motherboard. (On mine this is marked P1 and has a lock tab on one side that must be held in while unplugging.) Plug the 110-volt power and THEN plug the connector back into the motherboard. Button the case back up and all will be well until the next time you shut the power off to the computer.
The cause of this problem is likely that the battery on the motherboard is nearly dead. The flashing light is a warning to replace the battery. (It would have been nice if they would have put this into the user manual.) When you disconnect the power as described above, you interrupt the low-battery circuit. Replace the battery and all should be well.
Posted on Dec 02, 2008
SOURCE: hp laptop dv9500 noisy and loud fan ...
bro jast cheng the fane becos yor fane motor is week
Posted on Feb 14, 2009
Cd player says no disc when loading a cd jvc xl-z555
The lazer is not reading the info off of the disc anymore, You could try cleannig it, But that usually damages the lazer eye,They are verry costly to replace, your better off just to look for a different one, You can get a good use one now a days for $10 to $40 at the most,
Nov 06, 2012 | Audio Players & Recorders
I can't transfer files with my z555 to the pc!
Hii..luiz_augusto
to transfere file from handset to pc there need to make a synchronization with pc with help of usb cable and pc suite.
There must be a pc suite of your hand set be installed.
then connect your mobile to pc,there comes an option file transfer, select it and get the result.
Hope you will vote me.
Thanks
Aug 19, 2011 | Sony Ericsson Z555 Cell Phone
I have a sony ericsson Z555 mobile and the inside of the screen has accumalated dust.Can you advise how to clear it please
Take the phone 2 your local phone repairer to dismantle the the phone,clean the screen and then replace it back.
Apr 04, 2011 | Sony Ericsson Cell Phones
HP Compaq nc6000 powers up and then down automatically
check first the power connector.. and be sure that you power not auto shut off. then instal again the os.. even this vista or xp don'st matter...
as long as you powere is good condition..
Jun 13, 2009 | HP Compaq nc6000 Notebook
I have a wireless keyboard, model #9129URF that I need software to connect to my new computer. Can it be downloaded from your site?
This is a special 49Mhz frequency keyboard and needs the built-in hardware (found in the Z540, Z545, Z555, Z560 and Z565 media centers). If you do not own one of these, the software will load but not work...
Oct 28, 2008 | HP Computers & Internet
I have a sony ericsson mobile and when I try to send picture / photo messages it tells me setup required. For info, contact your operator or www.sonyericsson.com/support my phone number is 0402505936 and...
hi tiar514,
Try the below mentioned link to set up phone for picture messaging(MMS). By entering the required information you will get your MMS settings automatically to your phone.
http://www.sonyericsson.com/cws/support/phones/detailed/phonesetupmms/z555i
Thanks
Aug 28, 2008 | Lands Phones
I have a Sony Ericsson Z555 phone, all of a sudden i am not able to recieve text messages and people i send them to aren't recieving them! I am still able to make calls and everything else works just the...
try to check your message center number, there was a posibility that your message center number will be delited or changed by invalid center number, go to message setting and sending profile
Jun 02, 2008 | Ericsson Cell Phones
Presario v2000 display problems
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
HP z555 (PS501AA) PC Desktop Logo
51 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
