Question about Dell E151FPp 15" TFT LCD Flat Panel Monitor
Dell E151FPp 15 TFT LCD flat panel dim
The problem with the Dell is that the screen is dark. If laid down I can see the screen that all the info on the screen is fine. I tried to increase brightness but it had no effect. It works fine except I can't see it well enough because it is so dim. I took it apart and found three card. Power, circut and IC and video card. Which card would most likely be the problem child? Or could it be a diode on the power card? Seem if any problem existed with the power card it wouldn't work at all. Any professional insight would be appreciated.
Thanks
Hi,its either the inverter board has gone dead or the 2 ccfl lights are burnt.i have same problem.if both lights r dead ,im pretty sure the inverter is gone along with the 2 ccfl lights.all parts available n can b changed.my mail sabeersham@hotmail.com.
Posted on Mar 28, 2009
  • sham sabeer Mar 28, 2009
    dell e151fpp screen black out.
    Guru:
  • 859 Answers
Do you have the same issue when the cable is disconnected from the computer? If so, and the the brightness function doesn't change, then you have an IC Chip failure and the replacement boards are not available to you or me as Dell is Dell and everything from them is proprietary. If you are under warranty pursue that if not, time to replace. Consider this a time, unwanted time, but time to upgrade.
Oh, your right about the sacrificial diode on the power card... you wouldn't see anything.
Hope this fixed ya.
Regards,
Worldvet
Posted on May 15, 2008
I HAVE MONITOR DELL E151FPP, THE PROBLEM IN THE RESOLUTION WHICH IS 640 X 80 ONLY
Make sure you've downloaded the driver for your video card. As long as that is installed and it supports higher resolutions, you should be able to go to your system settings and change it (this process will depend on your operating system).
Mar 30, 2011 | Dell E151FPp 15" TFT LCD Flat Panel...
It does not have DVI port, only VGA.
http://support.dell.com/support/edocs/monitors/e151fpp/En/attach/attach.htm
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 17, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
E151FPp (Gray) 15 in. Flat Panel LCD Monitor: I am not able to get DIplay Driver for my LCD moni...
The 32bit color has nothing to do with monitor driver, that the video card driver issue, it sounds like you do not have correct driver for you video card.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | Dell E151FPp 15" Flat Panel LCD Monitor
Power Board Dell E151FPp
Did you check the fuse PF751, it should be less than 1 Ohm?
Also look for cold solder joints.
Mar 23, 2010 | Dell E151FPp 15" TFT LCD Flat Panel...
Sleep mode on a dell monitor
Hold down the function key on your keyboard (lower left hand side of your keyboard between the control key and the windows key) and the F8 key simultaneously. This cycles through all monitor set up modes.
Nov 22, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
DELL LCD SCREEN DARK SHADOW
check your tft backlights for burnt or breakage .
Sep 29, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
False color with Dell E151FPp and Mac Mini
a big issue with this..does the mac mini have the drivers for that monitor? only one way to find out..
www.mac.com has support and drivers, no?
Jun 16, 2008 | Dell E151FPp 15" TFT LCD Flat Panel...
Monitor goes black
it depends whether it displays anything. There's only one fuse which determines if the power is on or nor. If your monitor turns on, I would not look for the bad fuse.
Sep 29, 2006 | Dell E151FPp 15" TFT LCD Flat Panel...
Dell E151FPp 15" TFT LCD Flat Panel Monitor Logo
304 people viewed this question
Alun Cox
