Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
CADA VEZ QUE EMPIEZA CUALQUIER CICLO DE LAVADO,APARECE EL ERROR F1,PULSANDO CANCEL Y STAR,VUELVE A EMPEZAR EL CICLO, PERO, PARA DE INMEDIATO EL CICLO, CON EL MISMO ERROR ,F1, 3 VECES SEGUIDAS....ASI MISMO LO HACE AL HACER EL LLENADO DE AGUA PARA ENJUAGAR.. LA LAVADORA SOLO TIENE 1 ANO Y 5 MESES DE USO Y HACE APROXIMADAMENTE 4 SEMANAS EMPEZO CON ESTE PROBLEMA. GRACIAS.
  • Anonymous Mar 24, 2014
    no corta el llenado de agua y se rebalsa
  • 15,935 Answers
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&$%%
Posted on Sep 21, 2010
Tengo problemas con mi HHR la luz del T/C no se apaga y cada vez que pongo el cambio en Reverse o Drive hace un golpe en el motor, como puedo solucionar el problema?
Hola, Tengo Una HHR Y Cada Vez Que Me Aparece El T/C Me Empieza A Dar Golpeteos En La Caja Cada Vez Que Meto Drive Y Al Avanzar Da El Golpeteo De 1 A 2 Despues De Esto Tambien Me Aparece El Check y Al Aparecer Esto Ya no Enciende Desde El Control Remoto Yme Gasta Un Poco Mas De Gasolina Me Han Dicho Varias Personas Que Son Los celenoides Y Tengo Esa Duda
Apr 13, 2012 | Chevrolet HHR Cars & Trucks
Por que la lavadora no exprime y se queda quieta
Tengo una lavadora nave de 39 libras y cuando empieza el ciclo de lavado se queda quieta y el bombillo empieza a parpadear que debo hacer?
Mar 08, 2011 | GE Washing Machines
Hola. el prblema que tenia al principio con este
CERTIFICADO DE EXPERTOS AQUI TV, siga esta información que he proporcionado tres soluciones de largo a este tema / s
Solución 1
Antes de empezar a desmontar cosas, le permite probar su simple rutina retire el enchufe de alimentación y sistema de poder una copia de seguridad. También, por favor, intente su unidad en una canales diferentes para ver si el problema persiste en cada canal. Su principal del Consejo, Power Board, T-Consejo Regulador se sospecha que los problemas en este momento. Pulse y mantenga pulsado el botón de encendido durante unos 15 segundos, la unidad debe apagar por sí mismo después de haberlo encendido. Si no es así, entonces no te preocupes. Quiero saber si el problema persiste. El primer enlace a continuación le llevará directamente a la guía de solución de problemas si tiene que seguir adelante con el mismo error.http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Información adicional No se pudo TV y Monitores: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plaguepartes: www.shopjimmy.com
Le permite centrarse en la parte externa de la primera serie de televisión (95 por ciento de todos los problemas de la televisión están relacionados con cosas externas a la propia televisión) Compruebe la conexión física de todos los cables mediante la eliminación de cada cable pelado o RCA y volver a instalarlo (Cada cable de potenciaasí), una vez que haya quitado un cable, compruebe que no se deshilache, y si ya está desnudo, de empalme de una conexión nueva y fresca para ello. 5. Asegúrese de que NO hay otras radios uneeded, el sistema de las cercanías.estos sistemas, cuando se enciende, hará que la interferencia electromagnética y evitar que más que grave la interferencia de televisión SURGE PROTECTOR protectores contra sobretensiones representan más del 75 por ciento de las fallas eléctricas a los equipos de estéreo. Vamos a empezar con su toma de CA de pared. Es norma en América que 220 voltios de fuera de estos puntos de venta. Esto implica que cada dispositivo va a utilizar 220 voltios (dentro de esa zona de la red). En todo caso incluye un reloj de alarma está conectado a cualquier enchufe de salida de CA en las proximidades del equipo estéreo / TV, causará interrupción eléctrica, electrónica e impedir incluso de encender! El televisor necesidades dedicada energía eléctrica.Si el televisor se encuentra en la sala a continuación, desconecte todo lo demás en la sala de estar. Permite conectar el televisor a una toma de Dedicado. Revise todos los interruptores de luz para asegurarse que el poder es para el que toma. Compruebe el cable de TV para Desfibracion tanto en el extremo de la pared de CA y donde se conecta a la televisión.Compruebe todos los puntos de GFCI para garantizar que todos los botones rojo de reposición se empujan, compruebe los interruptores automáticos para la conexión adecuada y que están encendidos. Ahora, vamos a tratar el televisor sin que relacionada con cualquier servicio de cable, vídeo, dvd, equipo de música, etc Por favor, responda si hemos encontrado una solución.
Cuando la reparación de estas unidades, hay siempre varias variables a considerar. Primera visita para ver lo que ocurrió por última vez con la unidad, como hicieron los hijos juegan con videojuegos, ¿la electricidad salir debido al mal tiempo. Usted puede ver que hay muchas posibilidades, pero vamos a concentrarnos en lo que se produjo el pasado a la unidad. Una vez que determinemos lo ocurrido el pasado, podemos identificar la causa real del problema. La causa real puede estar asociada con problemas de proyección, las versiones anteriores (tubo de imagen), la interferencia de los dispositivos en las cercanías, e incluso una radio encendida y situada muy cerca de su unidad. Esto es normalmente conocido como interferencia electromagnética a la electrónica y es muy común el error que usted ha proporcionado hoy. Por favor, seguir buscando algo externo a la unidad antes de ver los componentes internos. He estado trabajando en estas mucho tiempo así que siéntete libre de seguir conmigo.
Jan 24, 2011 | LG Studioworks 552V 15" CRT Monitor
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Aparece la palabtra sud Que En El manual es Exceso
El "SUDS" error puede ser causado por demasiado detergente, detergente inadecuado, bomba de desagüe / drenaje problema de línea, o mal funcionamiento del interruptor de presión.
1. Si no está usando detergente HE, usted necesita estar. Estas arandelas están diseñados para usar detergente SE que se formula para las tinas de lavado que el uso de 5 a 7 galones de agua. Si utiliza un detergente común, que son, en el afecto, colocando una mayor concentración de detergente en la lavadora que normalmente se formulan para las tinas de lavado que tienen una capacidad de 35 galones. El fabricante debe contar con un descargo de responsabilidad en el propietario explicar este manual. En la mayoría de los casos esto también se anulará la garantía. NOTA: El uso prolongado del detergente equivocado puede dañar los componentes de la bomba de drenaje y / o lavado de sellos bañera.
Si está usando el detergente correcto, vuelva a revisar la etiqueta para asegurarse de que no es el doble (2X) o triple (3X) concentrado. Usted aún podría ser puesta demasiado jabón en su lavado.
Para deshacerse de demasiado detergente, coloque la lavadora en un ciclo RINSE & SPIN, a continuación, ejecute a través de un ciclo normal de lavado sin detergente agregó. Es posible que tenga que repetir estos pasos dependiendo de la cantidad de detergente utilizado.
2. Si usted no tiene un problema de detergente, vuelva a comprobar la fuga de la bomba y las líneas de drenaje para asegurar que no se obstruyan de ninguna manera. Retire el panel de pie inferior debajo de la puerta y retire la tapa de desenrosque en el desagüe de la bomba y verifique el colador. Obstrucciones en la bomba de desagüe y / o las líneas de desagüe se puede atribuir a la atmósfera quedar atrapado en el desagüe de la bomba y hacer que el código de error.
3. Revise todas las conexiones eléctricas a la bomba de desagüe y Unidad de Control Central (UCC). Usted tendrá que quitar la tapa superior de la lavadora para acceder a la UCO. Esto se logra mediante la eliminación de los tres tornillos en la parte posterior de la lavadora que sujetan el panel superior en su lugar. Con los tornillos quitados, deslice el panel trasero, y luego se apaga. La CCU se encuentra directamente detrás de la tina de lavado en el centro de la lavadora. El conector de la bomba de drenaje será el sexto conector (vistos desde el frente de izquierda a derecha) en el centro de la UCO.
4. Revise el interruptor de presión para asegurarse de que es bueno. El interruptor de presión se encuentra a la derecha de la CCU según se mira desde el frente. Es un pequeño dispositivo de forma cilíndrica con un conector y una manguera de aire conectada. El interruptor se puede controlar en varios niveles de agua quitando el tapón de la resistencia y tomar las lecturas a los pines del conector. Las lecturas son como sigue:
(Los pines se numeran de I a L frente a la de la parte trasera)
Los pines 1 al 2 (SUDS Detect) - 0 ohmios
Los pines 3 a 4 (cont.) - 0 ohmios
Los pins 4 a 5 (L1) - 0 ohmios
Pins 4 al 6 (Empty) - 0 ohmios
Espero que esta información tiene carácter informativo y útil.
Jun 18, 2010 | Kenmore Elite 45986 Front Load Washer
Pero cuando visito la pagina de youtube cual es el url por que me confundo un poco
el URL (Uniform Resource Locator) es una cadena de texto que identifica de manera única un recurso en internet (una página, una imagen, etc) de manera que se pueda acceder a dicho recurso en cualquier navegador, en cualquier sitio que visites, el URL de cualquier página que visites (incluyendo cualquier video de youtube) es la cadena de texto que aparece en la barra de direcciones, generalmente empieza con http.
May 15, 2010 | YouTube Videos
Compaq Presario sg3007la falla en conexion a internet
No sé si ya le habras sacade el Vista, pero por si las dudas te envio un link con los drivers para esa máquina, para XP. En MercadoLibrelos están vendiendo....increible!
http://rapidshare.com/files/151937645/drivers-xp-sg3007la.rar
Saludos
Jun 26, 2008 | Compaq Presario 12XL 104-106 Series 6X...
Problema para configurar internet wireles
dependiendo de c?mo conecting wirelessly, por el tipo receptor o PCi o tipo conexi?n del usb del cuaderno de PCMCIA, necesitar?s los conductores para todos los ?stos, pero no permites que a Windows los gen?ricos los funcionen pues no son siempre compatable. Si los has instalado, quitar el adaptador sin hilos si no se construye adentro pues no dices si tienes una PC del cuaderno o del tablero del escritorio, reinstalas el software, entonces vuelves a conectar el adaptador sin hilos. si es un cuaderno despu?s va al encargado del >device del panel de control y mirar en la lista para cualquier marca del exclamation como esto significa no hay conductor compatable, si no y ves que tu adaptador sin hilos lo enumer? est? trabajando muy bien, ut que puedes enderezar para chascarlo encendido uninstall selecto de la American National Standard y para recomenzar el cuaderno para que se reinstale otra vez para ver si soluciona el problema
Sep 13, 2007 | Computers & Internet
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
232 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
