Question about Frigidaire Refrigerators
Fan building ice on freezer side running loud
    Problem Solver:
  • 9 Answers
Fridge not going into defrost. That could be due to defrost timer in the fridge compartment next to thermostat, or the defrost thermostat in the freezer on the evap. Looks like a button on the cooling coils.
Posted on Sep 13, 2010
  • 263 Answers
SOURCE: ge gss22jfmcww side by side refrigerator warm
yeah if the fan does not work when you press the light switch thats the cause for the temperature proble, because the low temperature is not circulating stays just in one palce and yes you can replace just the fan get the manual from GE to see how to do it
Posted on Dec 30, 2007
  • 1462 Answers
SOURCE: ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Posted on Aug 23, 2008
SOURCE: Side by side (KSRB25FHSS05) loosing cool in freezer
jame open the back cover of the evaporator are in the frezeer section you will a type of radioator thats is your evaporator now check for frost if just frosted is ok if all iced up and a lot of ice then yoy have a defrost problem if no frost and compressor is running and you are sure of that then check the name plate for the date the unit was manufacture is less tha 5 years call a tech ou to check for freon or restriction ;leaks if less than 5 years is free but you have to be sure is running becuase the seal system in the only one under warranty ok
Posted on Nov 03, 2008
  • 72 Answers
SOURCE: Frigidaire Frig side by side making a loud buzzing noise
it sounds like the compressor, or something near it. it is generally the only moving part in a refrigerator other than the door, so would be my first guess. If it is constantly running, but staying cool in the freezer there may be a small leak somewhere or the compressor is losing power, and pumping slower.
Posted on Jun 15, 2009
  • 132 Answers
SOURCE: samsung model rsh1dbbp: fridge running
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Posted on Apr 01, 2011
Testimonial: "thanks for identifying problem. will get technician out to repair"
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
Freezer motor is very loud at times (up & down)
Sounds like Ice is building up and the fan blads are clicking on them. May not be something you can easally fix. Check the defrost system is working so the ice isn't building up and if that is working then you may need a control board that controls the defrost. Also when the fan isn't noisy ...make sure its actually running.. Could be a bad fan motor.
Good luck,
Jan 30, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The freezer fan makes a very loud noise
it probably has ice build up around i. Try manually defrosting it. Unpluggit and let it thaw out.
Apr 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
The freezer motor starts whenever I close the freezer door. It is loud and sounds like something is hitting a fan.
The evaporator fan motor inside your fridge is constantly trying to keep the temperature you have set it to. when the fan is on it circulates the cold air from your freezer in to your fridge. if you hear a banging noise it is cause by the fan hitting a build up of ice. this can be caused by a clogged drain pan or tube, not allowing water build up to be drained, or you could also have a defrost heater issue in which case you would have a large build up of ice near your fan. you can access the fan motor by removing the two panels at the back of the freezer, once removed you will be able to see whether or not there is a ice build up.hope this helps you
Thanks.
Oct 11, 2009 | GE GSL25JFPBS Side by Side Refrigerator
The refrigerator runs very very loud
The problem with that would possonly be the fan bearing is gone and gets load after a few min running or you have a ice build up and it is hitting the fan.To cheak on this you would have to remove the screws from the rear wall in the freezer compartmant and cheak.If there is ice build up you may need to order a defrost timer .If not you need a new freezer fan motor.hope this fixya:)
May 16, 2009 | GE Refrigerators
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge eterna refrigerator loud humming
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
GSG22KEPAFBB FREEZER VERY NOISY
15 mins or more is normal. noise could be due to ice build up round the fan - worth checking. otherwise fan could be noisy just due to age and needs replacement
Jun 22, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
Apr 15, 2008 | Frigidaire FRS23R4A Side by Side...
Refrigerators Logo
65 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
