Gree evaporator model GST36-22L/A[1] when the ac unit is put on E1 is display and you observe a constant blinking red light
4 Suggested Answers
rayname
  • 70 Answers
SOURCE: AC remote not working
www.gree-ac.com this is gree website you will need a model and serial number from unit I would contact them to see who your local suppliers are or online order remote m# and s# would also help if available
Posted on Jan 04, 2009
louislevel_2
  • 374 Answers
SOURCE: Formation of ice on evaporator element
hi! there,
eventually ice freezing evaporator occured two factor you have
dirty fin evaporator and undercharge system.
1. undercharge can easily detected using clamp
ammeter clamp on one line of evaporator while running
read the amper the compare this to yuor service
manual the rated current of the compressor.
2.if the reading current is below the rared current on
manual or there is tag on the body of unit specified
rated current.your unit need to recharge.
if has the same current no change at all freon is still
good, this only need cleaning of eveporator fin.
clean this by pressurise water to purge out all debris
particle on fin tube of evaporator.
cracking sound usally made by blwer or fan
misalignement or distorted bearing blower .
regards have anice day dont forget to rate me.
Posted on Apr 10, 2009
hvac1960
  • 2133 Answers
SOURCE: I get a E1 error code on my window ac unit. What
Indoor room temp sensor defective. Replace it.
Posted on Jan 01, 2011
Code error E7
I'm not sure if NewAir is made by Gree -- they supply many. On Gree units, E7 simply means one unit is requesting heating while another is requesting cooling and you can't have both at the same time. So that's the first thing to check. Very simple, very common, doesn't indicate that anything is wrong with the system.
Apr 05, 2014 | NewAir ACS-1200H Split System Air...
My ac is directly under a second floor ac, and water drips down constantly, now when I plug in the ac it shows E 1 on the display
The "E1" code indicates a compressor sensor failure. Did the dripping water from above cause the problem? Possibly , but there's no way to prove it. If you'd like to order the part and replace it yourself, call 800-313-8495. Have your Model Number & Serial Number handy when you call. If the unit is still under warranty and you have your dated Proof of Purchase call 1-877-337-3639.
Hope this helped you and tanks for choosing FixYa.
Aug 08, 2011 | Haier ESA3109 WallWindow Air Conditioner
Dell vostro 9lock button blinking and no display
Hi sarwankuma5,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 17, 2011 | Dell Vostro 1500 Notebook
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
My new gree air conditioner split system has an E1 error
My greewall mounted has a e1 prblem.how van ifixor what is the problem
Feb 09, 2010 | Heating & Cooling
Jan 04, 2009 | Heating & Cooling
Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Aug 11, 2008 | Fujitsu 24C1 Air Conditioner
I have a saeco expresson machine
Try to take out the dregdrawer for 20sec and put in again.
You can also try to open the steam knob and make a cup of water.
Jun 06, 2008 | Saeco Coffee Makers & Espresso Machines
Open Questions:
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
