Question about Pride Jazzy 1650 Heavy Duty Power Wheelchair
Lights continually blink on and off on the joystick controller
  • 4,323 Answers
Hi
Your power chair has a manual freewheel lever located on each motor. Manual freewheel levers enable you to disengage the drive motors from the gearboxes and manoeuvre the chair manually. However, if you try and disengage the motor while the power is on you’ll get the blinking lights on the joystick. To clear this code, turn off the controller and place the power chair in drive mode. Then turn on the controller. The error message should be cleared.
To engage or disengage the drive motors:
1. Locate the levers on the front of the power base. See figure 8.
2. Push the two levers inward to engage the drive motors (drive mode).
3. Pull the two levers outward to disengage the drive motors (freewheel mode).
If a lever is difficult to move in either direction, slightly rock the power chair back and forth. The lever should then move
to the desired position.
WARNING! Do not use the power chair while the drive motors are disengaged! Do not disengage the drive motors when the power chair is on an incline, as the unit could roll on its own! Only engage the freewheel mode when on a level surface.
WARNING! It is important to remember that when your power chair is in freewheel mode, the braking system is disengaged.
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 13, 2010
Invacare TDX SP. how can I be sure it's charging? Should there be lighted indicator on control screen?
Not a specific charge light but the battery level lights should blink. If you have no lights that turn on on the joystick when you turn the joystick on then the chair is not charging, Do any lights turn on when you plug the charger into the chair then into the wall?
Feb 06, 2018 | Invacare Health & Beauty
Tip
UnLocking Sleep and Lock Modes for Pride and Invacare power chairs
<p><b><span>Pride Joysticks and others that use VSI joysticks</SPAN></B><br><p><b><span>SLEEP MODE</SPAN></B><br><p><span>Your VSI controller has a sleep mode feature. Sleep mode is a built-in circuit </SPAN><span>that automatically shuts off the main power if the joystick is not moved </SPAN><span>in any direction for a period of time predetermined by controller program.</SPAN><br><p><span><b>The battery condition meter lights on the keypad indicate sleep mode by </b></SPAN><span><b>blinking once every five seconds.</b> To restore power and continue, push the </SPAN><span>on/off key twice.</SPAN><br><p><span> </SPAN><br><p><b><span>Lock Mode</SPAN></B><br><p><b><span>To unlock the VSI:</SPAN></B><br><p><span>1. Press the on/off key and power on the VSI. <b>The maximum speed/profile </b></SPAN><span><b>indicator should ripple side to side</b>.</SPAN><br><p><span>2. Push the joystick to the full forward position until the VSI beeps.</SPAN><br><p><span>3. Pull the joystick to the full rearward position until the VSI beeps.</SPAN><br><p><span>4. Release the joystick. There should be a long beep.</SPAN><br><p><span>5. The VSI is now unlocked.</SPAN><br><p><span> </SPAN><br><p><i><span>Invacare and others that use SPJ+ joysticks</SPAN></I><br><p><i><span></SPAN></I><i><span>FOR SPJ+ Joysticks</SPAN></I><br><p><i><span><b>Lock Mode will be indicated by all LEDs</b></SPAN></I><br><p><i><span><b>flashing briefly and the information gauge</b></SPAN></I><br><p><i><span><b>LEDs chasing slowly from right to left</b>. If</SPAN></I><br><p><i><span>this occurs, press the horn button two times</SPAN></I><br><p><i><span>within ten seconds to unlock the joystick.</SPAN></I><span></SPAN>
on Nov 16, 2010 | Health & Beauty
I have a merits p313 electric wheelchair stop working put in new batterys the controler lights all blinking then just middle yellow blinking
have lights so not fuse blown
not much to these ..batteries .. controller .. electric motors
hard to mix up the positive and neg terminals
that is a two battery unit
check if the joystick controller or its cable is faulty
Jun 24, 2016 | Electric Health & Beauty
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
When i plug the cable into the joystick control (MK5SOJ+) all the lights around the horn button blink on and off motor wont engage and it won&#39;t shut off til pull out the cable do i need a
When you say the power cable I hope you mean the cable that comes from the main control module under the chair. I want to make sure you are not talking about the AC power cable that plugs from the chair to a wall outlet. So if we are on the same page about the cable is the one going from the joystick to the main control module under the chair and all you do is plug it in and the green speed lights start to blink this would indicate the joystick is bad.
Jan 23, 2015 | Invacare Pronto M51 Power Wheelchair
Blinking lights on quickie p220 joystick chair will not move
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Sep 10, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Lights blink in sequence of 7 when turned on
The 7 flashing lights indicates the VSI controller joystick has an internal fault requiering replacement. Call your local mobility store that does repairs or willing to sale the controller joystick to you. Inquier if you health insurance will help. These VSI controllers can cost upto $1300 - $1600 new. If you live in Utah you can try the Intermountain Homecare Custom wheelchair shop. Hope this helps.
Feb 02, 2010 | Pride Jazzy 1103 Ultra Indoor Power...
Joystick is not finding the wireless receiver
On the front of the usb reciever you will see a green flashing LED. This is actually a button which when pressed will then start to blink more rapidly as it is now searching for the controller. If you then immediately press a button on the controller whilst these rapid flashes persist it will find the controller. Both reciever and controller will now show solid LED lights. Voila job done .....happy gaming:P
Dec 06, 2009 | Logitech Cordless USB Freedom 2.4GHz...
All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Apr 28, 2009 | Jet 3 Ultra Power Chair
Saitek X52 Joystick
Try deleting the drivers for the joystick, visit Saitek website get latest drivers and re-install the joystick, might fix the problem.
Nov 23, 2008 | Saitek (PS28) Joystick, Throttle
Pride Jazzy 1650 Heavy Duty Power Wheelchair Logo
143 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
