Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
I have a MTD ride-on about 3 years old which has an electrical problem. When trying to start the mower the engine doesn't crank. I can hear a "clicking" noise from below the seat. I would have thought this sound was that of the solenoid but it is not coming from the engine /starter motor. I can start the engine by "hot wiring" direct to the starter motor. Could there be some sort of relay under the machine that is faulty?
  • 1 more comment
  • Jim Parker
    Jim Parker Sep 13, 2010
    What have you tried to do to it, anything? Jm
  • jackchaff Sep 13, 2010
    No, sorry. I only have a little knowledge about machinery. I have a portable battery /starter pack that I use on the car if I have a flat battery. The sort you connect to the battery terminals, wait 3 minutes and start the car. I tried this on the mower by connecting it to the battery terminals as I would with the car but still only got the clicking sound. Then I changed the battery in the ride-on mower (to make sure it was fully charged) and heard the same noise but the engine wont turn over. Then I connected the starter pack to the mower starter (turned the key on) put the negative clamp on the body and touched the positive lead to the starter and away it went. I mowed an acre of grass and turned it off. It would not restart again unless I used the starter pack again. Cheers, Jack
  • jackchaff Sep 25, 2010
    Found the problem. Solenoid needed replacing. I didnt realise the solenoid was poitioned under the seat.
  • 1,041 Answers
If you know that the battery is good, then it is the Magneto, (This is the part responsible for recharging your battery as you use the mower.)
However, your battery may be bad and no longer receiving a charge. Take it to a local auto parts store and they can test it for free.
Good Luck!
Jim
Posted on Sep 13, 2010
  • Jim Parker
    Jim Parker Sep 25, 2010
    Sorry I didn't point you toward the solenoid. I should have figured that. :-(
    Thanks fort he update.
    Jim
I have a Troy-bilt riding mower with 20 hp Kohler engine. Battery was going bad but I was able to charge a few times successfully. The last time, the seat fell forward onto the charging battery and
Okay according to the electrical diagram the lights are powered by the alternator only when the engine is running so the engine must be cranking. If so then you may have somehow reversed charge the system. If so then the ignition coil would be blown and possibly even the alternator depending the engine setup. It doesn't take much more than momentary reversal to do this. When cranking test for spark at the plug gap while is removed and grounded. If no spark I would think the coil has died. If you getting a spark then check fuel cutoff solenoid on the carburetor to see if it working even a reverse 12 volts won't hurt it.
I am including a copy of the electrical diagram so you can do electrical checks on the system, Good Luck
Electrical Diagram
Nov 15, 2014 | Garden
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
I have a 12.5 hp Briggs lawn trator that has a good spark, fuel, compression but will not start. I tried to use starter fluid with no luck. When engine cranks, carb intake has vacumn and some smoke comes...
Since the engine is newer, I presume it has an OHV train. The valves may need adjusting. Also,the engine may be out of time. A sheared flywheel key (not too hard to fix) may be the timing culprit there. Has the mower blades ever struck anything besides the usual yard growth?
Remove the engine's top cover and look down the slot in the side of the crankshaft alongside the flywheel for the key that holds it in place. If the slot in the flywheel isn't lined up with the slot in the crankshaft, then it is out of time and won't start. There are many tutorials and specification charts for Briggs OHV valve adjustment available. Post back as needed.
Jan 11, 2011 | Mtd Garden
CubCadet 1554 - won't start!
If you hear the PTO click when you turn the ignition on, sounds like the PTO button is pulled out like you were engaging the blades. The engine will not start if the PTO button is pulled out....
May 07, 2010 | Oregon Scientific Electric PTO Clutch for...
Ride on mower drive problem
sounds like a belt to me not tight enough against the pullys
Nov 09, 2009 | Mtd Gold 42" Zero-Turn Mower -
Mower wont start just clunks battery ok
SOUNDS LIKE YOU DUMPED SOME EXCESS GAS IN ENGINE,PULL PLUG(S) AND CLEAN OR REPLACE, CHECK CYLINDER FOR EXCESS FUEL BY CRANKING WITH PLUGS OUT,SHOULD SPIT ANY EXCESS FUEL OUT OF HOLE,REPLACE PLUGS AND TRY TO START.
Apr 08, 2009 | Mtd Garden
Ignition does not crank engine
If it is cranking over it should start. If you are just jumping the solenoid then you have a switch problem.If it is just plain not starting then you need a complete tuneup. It a process of elimination, you need air, gas, and a spark. Then it will run.donnyb60
Mar 22, 2009 | Mtd Garden
Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
410 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
