Question about HP Computers & Internet
Hp g60-230us: Motherboard, screen, or other? Turned working laptop off, put in padded bag, drove 3hrs, no trauma, plugged p.s. in and turned on, screen had strange blotchy look then displayed left 1/2 blue, thin vertical grey line, and the right was black after warming up. Drove home, no screen activity, video does drive external monitor. Number keys not working, and can't enable num lock. Using right now with external monitor. Not in a position to replace laptop, or "hang" parts until I find the problem, would like to move forward with confidence that buying one part will fix it.
  • 734 Answers
HI there,
I'm a pro laptop repair/rebuild tech. I do not believe the numbers lock and screen are related excepting that the screen plugin on the board affected a curcuit when the screen failed, which is exactly what your problem is. I would replace the screen and the inverter (directly under the screen behind the bezel at bottom) and you should be good to go.
Best Regards,
Marcus
Posted on Sep 13, 2010
  • 2 more comments
  • nonspam976 Sep 13, 2010
    Thanks Marcus, I like the screen as the culprit, took it apart to pull actual part numbers. $150 should cover both pieces and shipping; ordering tomorrow.
    Michael
  • Marcus
    Marcus Sep 13, 2010
    You're most welcome!
  • nonspam976 Sep 20, 2010
    Situation update: Inverter came a few days ago, screen just arrived. Hooked new components up, all systems are go. Check some images I edited with a less desirable screen (2-3 minutes). I'm happy as a kid on Christmas morning. Turn everything off, and assemble it propperly, screws in place covers on, fire it up...VERTICLE LINES! I could cry :( What is happening here? Someone please help, I'm so frustrated, I wish I was in a position to throw money at the problem.
    I pulled the battery and power to put it back together. What does it indicate that on power up something was going on in the background and required 5-10 minutes of the hard drive doing busy work before I could observe anything on the external montitor?
    Oh, for the record I think your advice was sound, there must be other issues here.
Common Issues with HP Compaq Presario X1010US (DK571A#ABA) PC Notebook - page 118
COMPAQ from 2005? its old .
no photos presented so, answers will be wrong to bad.
why fix this old LT
why do that? put good money on top bad.
buy a used laptop 2010 or newer. and now much better.
HP does not support this LP.
you could send here $200 to fix it. why ?
but used MOBOS can be cheap for the Dead products like this.
nobody wants to own them or fix them so scrap em.
Get HP8540w ,
IMO best they ever made. "not fragile" like Spectre bs.
Apr 11, 2017 | HP Compaq Presario X1010US (DK571A#ABA) PC...
Well my laptop turns on the lights turn on but a blank screen, i think the mother board as gone but not sure.. what..
there is a experimental method to bring your notebook to life 1. put a scotch tape on every cooling hole on your notebook 2. put the notebook in a nylon bag and powered it on for about 1 hour 3. notebook may be shut down after a 30 minutes remove it from the bag and remove all scotch tape and put your notebook on the table for about 30 minutes to cool down than try to powered it on with this method fix my dv 6000 pavilion :)
Dec 12, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Hi I have started my HP PAvilion dv9310us notebook all the keyboard lights are on but nothing is displayed on the screen it seems the notebook is turned off but it is on and running.
lights are on but nobody is home.
This is a problem seen in a couple of HP model lines (dv, and tx).
Short version...
Your motherboard is shot, I hope you are still under warranty as HP hasn't owned up to the design flaw that causes the problem enough to do a recall or offer replacement.
IF you have critical files that you need to get from the machine you may try the following, however this is not a long term solution...
1) turn pc on (lights are on fans are running, no hp spalsh screen, no nothing)
2) put pc in a bag (what ever you would carry your laptop around in should work, or wrap in a towel, the point is that it gets really hot)
3) wait 20-30 min.
4) turn pc completely off (hold power button for several sec or unplug and remove battery)
5) try rebooting (you may have to try a couple times, and I have a superstition that holding down F10 while powering on helps, once you see the HP splash you should be good to go)
6) Remember that HP makes devices with all kinds of cool features, but they almost always fail shortly after the end of thier warranty.
Nov 23, 2010 | HP Pavilion dv9310us Notebook
HP Pavilion ze2308wm won't boot up
Have you tried an external keyboard, either PS2 or USB depending on what ports are available?
Mar 14, 2010 | HP Pavilion ze2000 Notebook
Mouse pad's not working
HAVE YOU REDONE THE DRIVERS IF PRESS ON THE PANEL AT TOP OF PAD DOSE WORK IF IT IS A BORD PROB SAME AS HP NX6110
Jan 31, 2010 | HP Pavilion dv4000 Notebook
Hp not turning on laptop
you haven't got the TFT cable plugged in correctly
Jul 25, 2009 | Computers & Internet
My screen light just turned off, but i can barely see my desktop and the taskbar. what happened?
sounds like either the ccfl tube died or your inverter died, a easy way to test this is to take a old working laptop, remove the screen bezel on both laptops and dissconnect the plug leading to the screen (usally a pink and white wire cable and connect the cable from the hp to the inverter on the old laptop, power on both laptops and if the hp screen lights up then the inverter on your hp is dead, this is not uncommon on laptops and if you ever get a new laptop try to get one with led backlight technology, if the inverter from the old laptop has the same plugs, put it into the hp, otherwise order a new on
Jun 14, 2009 | HP Pavilion dv7-1130us laptop
My toshiba laptop won't turn on!
Place the battery back in and the power cord. Follow the power cord all the way to the plug and verify nothing was unplugged by accident. (the box on the plug sometimes disconnects without the user knowing it) This could have caused your lack of power. Hope this helps.
May 09, 2009 | Computers & Internet
Laptop LCD screen failure
when you hooked up ur laptop to an external monitor, did you adjust the display settings, you have to do that if ur operating system is xp or older.
Aug 24, 2008 | Computers & Internet
Computers & Internet Logo
355 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
