Question about Pride Jazzy 1650 Heavy Duty Power Wheelchair
Lights on joy stick controller blink on and off and chair wont move
  • 692 Answers
Cezna Are the lights that are blimking the battery level lights or they the speed level lights. If it is the speed level lights then the chair thinks you still have the charger plugged in. If it is the battery level lights do a certain number of lights flash 3 lights flashing 4 lights flashes etc this is the flash code and will tell you what problem you have. It could also mean that you are in lockout or sleep mode If you have the VSI joystick then turn on the power immediately push the joystick forward and hold until you hear a beep then mmediately push it to the rear til you hear a beep then immediately let it return to the center position. If it was in sleep mode this should wake it up. Hope this helps you
Posted on Sep 13, 2010
  • James Rose Oct 17, 2010
    Had the same situation. I found that the cable from the joystick to the controller was partially disconnected. Pushed it together and it worked fine.
Light come on controller no flashing code lights joy stick does not work
The M51 could have the motor clutch levers in the free wheel/push mode and the joystick will not blink if this is the case. Make sure that the chair cannot be pushed. If it can be pushed it means it is in free wheel and you need to lock the motors in gear.
If it is in gear and the joysticks green light does not change color or blink it could be that the joystick is bad. When nothing happens and the lights don't blink when you push the joystick knob the chairs controller basically isn't recognizing the joystick movement.
Time to have the joystick repaired or more. Have a technician look at it.
Jun 16, 2015 | Invacare Pronto M51 Power Wheelchair
My chair will not change speeds. Very slow, No flashing lights
That is possible. Check the power circuit from the battery and see if there is any loose connections or resistance in the circuit via the voltage drop method. Here are some links that may help:
Jazzy 1113 ATS Parts
Redirect Notice
Redirect Notice
Mar 03, 2015 | Pride Jazzy 1113 Power Chair
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
Jazzy 1113 power chair shows charged but control light is blicking. Chair will not move.
It appears that the controls are in Lock Mode. Unlocking Instructions depend on your type of controller. Go to PrideMobility.com to download the proper manuals for chair and controller.
Feb 11, 2013 | Pride Jazzy 1113 Power Chair
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
Not sure witch jazzy chair i got but the joy stick blink and keeps blinking i have tried pushing horn button twice and also turning it on and pushing joy stick forward waiting for it to beep but no beep....
The jazzy probably has a VSI controller and if it is sleep mode then the lights will scroll rather than blink. Now turn on the chair and see if the blinks have a pause between them, ie 4 blinks pause 4 blinks pause etc If they do count the number of blinks and this will give you the error code ie 4 blinks right motor 3 blinks left motor your owners manual should have a chart listing the error codes If not you can contact Pride tech support @ 1-800-800-8586 ask for jazzy tech support
Hope this helps
Feb 17, 2011 | Pride Jazzy 1103 Ultra Standard Power...
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mimobility
Joystick not moving chair,a blinking light on keysign on joy stick panel
You need to check the little fuse and see if it is blown, if it is replace it, if not, it is like a 'check engine light' on a car, most of the newer chairs need a diagnostic test ran.... Guy
Sep 06, 2010 | Dmm Allure HP6 HD - Used Electric...
Merits DL 52 i electric wheel chair, all leds flash 3 times as a error code. Battery is fully charged, then turn on wheelchair. All led are on. then when the joy stick is pushed, all leds flash 3 times...
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Jul 15, 2010 | Health & Beauty
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Pride Jazzy 1650 Heavy Duty Power Wheelchair Logo
836 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
