Question about Vacuums
HELLO MY nilfisk king 540 cable will not retract. I have taken the machine apart and the coil has now come off the small spindle. is there anything you can do to help me
Cable will not retract
If you are having problems with a NIlfisk King cord reel it will either be that the cord is simply dislodged or the retract could be faulty. I have made a video showing how to pull it apart which could be used as a reference to diagnose the issue.
If you need a new retract we have these available online as well, the part number is 22352606 Nilfisk King Cord Rewind
Feb 18, 2012 | Nilfisk Vacuums
Looking for repair manual on the Nilfisk Kink Type Great Dane
I would be happy to send you a parts diagram for your machine if you want to request a diagram through he contact us form on our website. I have also made a video pulling one of these machines apart which may be helpful.
Jan 20, 2012 | Nilfisk Vacuums
GM310
Hi There,
I have made a video showing how to get one of these vacuums open have a look at that to see how it works. If you need any Nilfisk parts you can find just about anything for Nilfisk from VacuumSpot if you are in Australia or NZ
Jan 12, 2012 | Nilfisk Vacuums
Looking for details for fitting dust bag in nilfisk king hoover
Hi There, I have made a quick video showing how to check the filters and also how to change the Nilfisk King Vacuum Bag. Take a look and you should be able to work it out.
Aug 30, 2011 | Nilfisk GDF2040 Vacuum
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
Nilfisk king 540: The cable is stuck. I can´t take it out
Tools required: Haxalobular screwdriver (Torx or 'Star'), Strong hands/fingers, flathead screwdriver.
Possible hazards: sharp edges (metal plastic), bacteria enriched dust/dirt.
Notice the black ring/skirt near the bottom of the unit...sit on the vacuum cleaner, and pull very firmly at the ring, which will begin to click and pull upwards, rotate around the unit pulling the ring up until the whole ring comes off and you can pull it off over the top of the unit.
Now, there will be a white plastic ring revealed around the unit, using a Flat Head screwdriver to pry the ring out of the grooves it sits in (pull it off towards the bottom of the unit as opposed to the intial black ring coming off upwards).
Now take the handle of the unit and give a firm **** upwards, the whole encasement will slide off in your hand.
You will now see the spring loaded cord retracter. The problem here is that the spring has become too losely wound back onto the larger spindle, or it is dirty.
Firstly pull the entire power cord through the outer shell that you removed (you will need to unscrew and remove the black facade that the cord goes through otherwise the head of the cord wont go through).
Then take the plastic cirlce cover off the smaller spindle (carefully as the wound tin spring could pounce).
Now you need to manually turn the larger wheel clockwise until it has no coil left on it, and the smaller coil now is full.
While winding, dont let the powercord wind back onto the wheel, let it sit to the side (there will be a bit of tangle which will go back to normal when we finish winding back the other way).
Once it is fully loaded onto the smaller coil, wind it back on to the larger coil again, but make sure it's loading on 'tight'. You can ensure this by keeping some pressure on the smaller spindle while winding (be carefull because the coil edge is sharp). Once the smaller coil is basically gone and there is just a small curved end of the coil, put the small spindle back on making the curved coil wrap around it.
Wind some coil back onto the smaller spindle so there is atleast one full ring plus a small overlap, around the spindle, or it may come off. Also, make sure that where the cord is coming out of the larger spindle, is pointing towards where it goes out the back of the vacuum cleaner, so that when you pull the cable it wont wind the wheel at all, otherwise it may wind some coil off the smaller spindle.
Proceed to put the unit back together, but before putting the white and black rings back on, test the retract button. I noticed the first attempt to put it back together that the external button had not lined up with the internal mechanism and it wouldnt retract, i had to open it again.
All done, it should now retract, but it will never be as strong as the day you bought it, but atleast you dont have to have the cord hanging round. Hope this helps.
May 18, 2009 | Vacuums
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Vacuums Logo
114 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
