Question about LG 42LC2D 42 in. LCD HDTV
My LG LCD TV (42LH55) won't turn on. The power light is constantly flashing. What should I do? I tried unplugging, turning off main power switch, turning TV on at the TV...
SOURCE: LG LCD TV Standby Light Flashing Red Continuously
I have had this same problem twice in the past 3 months. So far both times I've been able to get it back after a week or two. I'm not sure what works, but unplugging and detaching the antenna and cable and waiting a few days seems to be the key. In both instances, I unplugged it for a few days then plugged it in for a few days and repeated the processes until I eventually got the steady red led. Both times prior to the red led the led would flash red then green and make a clickiing noise for several hours before I was able to get it working again.
Posted on Apr 22, 2008
SOURCE: LG TV
There is probably a bad capacitor on the power board, I had the same thing happen to my 42LB1DR after 2 years. T.V. would turn on and white power light would blink, no pictue and no sound. If your'e a diy'er, it is not that hard of a fix. Take all the covers off of the back of the tv(UNPLUGGED!!!), then look at all the capacitors on the power board. lcd_repair_4_bad_capacitors_lg.jpg
These are the capacitors, look to see if any of them appear to have a bump on the top of them. They are supposed to be flat, you can also tell if one of them has gone bad if there is an oily substance on the metal cover that was removed. If one of them is in question, carefully remove the board, and take it to an electronics store to have them sotter ?sp on a new capacitor. It ended up costing me around $40.00 to have this done. Good luck and if you are not comfortable trying this, than take it to a repair shop, but I was quoted around $450 to take the T.V. in. No Thanks
Posted on Nov 21, 2008
  • 187 Answers
SOURCE: how to reset lg lcd tv
Whe you press the power button the TV led have to blink several times and the it have to change to blue, meaning Tv is on.
If you press the power button and the led start blinking and goes off, then you need to replace the mainboard because it is damaged.
Bye
Posted on May 27, 2009
  • 2336 Answers
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
Posted on Jun 08, 2009
  • 257 Answers
SOURCE: samsung lcd tv le40r8. tv will not switch on.
The problem is the mainboard tried to turn on TV but failed due to internal circuit problem. Normally, the power supply board is malfuntioned.
Posted on Aug 13, 2009
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
I have a Sony Bravia LCD tv an it won't turn on at all the standby light is not even there I've tried turning on an off and leaving unplugged for an hour still nothing.? Help,
You either have a problem with your power supply board or main board. I would start with having the power supply fuse checked as well as the power supply board!
Jan 26, 2013 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
My LCD tv turned off and then flashed a red light and then I unplugged it and then tried to turn it back on and it didn't it just had a yellow flashing light. Then I left it unplugged for a little bit...
your power supply need to be check. Some of the capacitor needed to be change for there where worn out or blown on top. The voltage that he need couldn't be attain so the capacitor need to be charge longer. this occasionally happen to all switching power supply
Aug 13, 2011 | LG Televison & Video
Tv wont turn on
Hello Charliebigwh, hi technically your monitor's power supply has a problem, this is either your switching regulator does not work or there is a short in that section, If you want to do it your self, need to replace all large value, and or high voltage capacitors(especially the capacitors with its top is bubbly), need also to replace the switching IC, and power transistor.
Have it checked by a technician if you cannot do the work.
Apr 15, 2010 | LG 32LG30 32 in. LCD HDTV
LG flat screen wont turn on. Ive tried unplugging from wall
The flashing light indicates the TV is in protection mode. Most likely logic board. Not sure what your model is but its usually the board that has your digital inputs in it ex HdmI etc. Post your model and you should get some one to post more info Ex ( LG XXX has a common problem with tuner board)
Oct 16, 2009 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
87 people viewed this question
