Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
My HP Pavilion f1503 will not turn on, - HP Pavilion F1503 15" LCD Flat Panel Monitor
  • 11,361 Answers
Check the power supply caps, solder joints first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Sep 13, 2010
viziks
  • 220 Answers
SOURCE: HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Posted on Mar 04, 2008
SOURCE: pavilion f1503
i have a problem with this monitor too. i have been plugging it in and turning it on and i see that the display is working fine but the black light only stays on for a split second. i did take it apart and checked the lights and found that the top black light is not turning on while the bottom one stays on for a split second. i believe there is a problem in the circuitry and if i do need a new piece how much would this cost?
Posted on Mar 25, 2008
SOURCE: hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Posted on Aug 19, 2008
SOURCE: inverter problem
1800652667 as soon as hurricane Ike gets done with Houston, Texas. Or www.hp.com/go/support
Posted on Sep 13, 2008
  • 111 Answers
SOURCE: Hp pavilion f1503
If you can see a very faint image in the background on the the monitor it is a invertor or backlight issue, try resoldering the coils on the monitors mainboard, This is a common issue with this model
Posted on Dec 03, 2008
How do i replace the back lightin an hp pavilion f1503?
Spare fl-tube is expansive. Not worth the trouble. Just buy a new monitor with LED backlight.
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Moniter will not turn on
Check the AC adapter to make sure you do have 12vdc coming out, just need to narrow down the problem before taking the monitor apart.
Apr 05, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Mouse hanging up
is the mouse wireless?(try a new batt) optical,try another mouse.
Dec 25, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503
Nov 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Inverter problem
Jul 21, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion 1503 monitor lcd
Believe it or not, I got given a f1503 not working but without the power cable. He said the same thing everyone else is saying. I did not have a 12 volt 3amp converter but a 12 volt 1.5 amp converter. Plugged it in turned it on and wow it worked fine. It has been working for 1 week on with no problems. So try a different power converter, worked for me.
Jul 06, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
