Question about Syntax Televison & Video
No volume on the TV - Syntax Televison & Video
  • 21 Answers
Make sure the mute button is not pressed. Are you using a cable or satelite box? If you are and just hooked it up or moved it then the cords code be in the wrong colored jacks.
Posted on Sep 13, 2010
When i first turn on tv sound is fine . then it will drop down in volume badly .
Many newer types of TVs have what's called "Volume Leveling", which means the TV automatically lowers the volume if a sudden increase in the broadcast signal volume is detected. Check to see If "Volume Leveling" is present on your TV and currently turned "on". Refer to your owners manual for this. It should be in the Audio section in the menu on your TV. Turn the "Volume Leveling" to the "off" position to disable "Volume Leveling".
Jan 23, 2016 | Televison & Video
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
Dec 15, 2015 | Emerson Televison & Video
There is a "hissing" sound on low volume. Whazzup?
Do you have a cable box connected to it? I'm sure you do .. You might have the TV or the cable box at max volume ..
If you are using the TV as the main volume control try to lower the volume from the cable box, maybe to mid volume.
If you are using the Cable box as the main volume try doing the opposite from the above..
Hope this helps.
Sep 21, 2010 | Vizio VL260M TV
Very little volume, not very loud at highest
On the TV-use your finger to adjust the volume level, about midway, then use the remote to shut off the tv, then turn on tv with remote. Volume level should be better! If still not loud enough...using your finger on the tv...turn up volume & repeat remote steps.
Jan 19, 2010 | Universal Remote Control DIRECTV Universal...
Having connected up my PVR915OT I am unable to increase the volume on the TV to a reasonable level of volume using the Humax handset- can you offer a solution please?
As far as I recall, the volume control on the PVR remote only controls the volume from the PVR. So, select the volume fully up (using the PVR remote) then increase the volume on the TV (using the TV remote) until it's as loud as you can stand. You can then adjust (decrease) the the volume to suit using the PVR remote.
Jan 13, 2010 | Televison & Video
Low volume on some channels
Well, some TV stations do broadcast at different volume levels. This is very noticeable when watching a TV show and the volume seems normal and then when a commercial comes on, the volume is very loud. They do this to get you to pay attention to the commercial. Another problem might be that you are adjusting volume from both your TV and your cable box. What you should do is make sure your cable box is set to "FIXED VOLUME" and then just adjust your TV volume. Fixed volume will have the cable box output only one volume level, letting the TV do the adjustment. Just go through your cable box setting and look in the audio settings. Hope This helps...
Mar 14, 2009 | Element Electronics FLX3711B 37 in. LCD TV
Volume is very low
Use the satellite receiver remote control to adjust the volume first. The receiver itself offers volume control and you probably have that turned down. Then you are trying to raise it with the volume control on the TV. This is raising the TV volume, but there isn't much sound there in the first place. Use the receiver remote, and you will probably see a volume bar. At some point it might say something like "best stereo" or a star might appear. If that happens leave the volume set there, otherwise just raise it all the way. Then control the volume with the TV remote, or program the DirecTV remote for your brand of TV, and the volume button should control the TV then.
Dec 19, 2008 | Toshiba 32AF43 32" TV
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
WON'T CHANGE CHANNELS ADJUST VOLUME OR SHUT OFF
If the volume buttons work when using the Radio, then the buttons on the Remote are fine.
Now if the volume on your TV is set to MAX and you can barely hear it.
The issue lies with your TV.. ()
Now if I understand correctly or if I am to assume you are using a Reviever.
If the reciever is used for all volumes... If this is the case.
I also assume the volume on the TV Speakers is set to off
Therefore when you use the Radio/DVD the volume control is using the Reciever volume.
and when you switch to TV it uses the TV volume thus the TV volume is not gonna work as well.
2 scenarios
1 The TV volume even at max is not giving you enough power to get the low receiver volume
2 the Receiver volume is at max and barely audible.. if this is the case just manualy adjust your TV volume to get it to a decent sound level.
Hard to explain but I know the 2 issues can be fixed.
Apr 21, 2008 | Logitech Harmony 550 Remote Control
I found that the problem was also with my HD box. I was able to turn the volume up on the box.
Mar 02, 2008 | Sharp Aquos LC-26GD4U 26 in. LCD HDTV
Televison & Video Logo
95 people viewed this question
Top Syntax Televison & Video Experts
Jaime Hernandez
Kolbrun...
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
