Question about Yamaha DSP-A1000 5-Channel Amplifier
Lost remote control for Yamaha dsp-a1000
Can I use the remote control for the Yamaha RX-V2095 by changing some control code so that I can use it on the Yamaha DSP-A1000?
5 Suggested Answers
  • 236 Answers
SOURCE: dsp-a1000 dead
output stage problem, systems trips due to protection. have the power amp transistors checked. the rotating of function switch is normal, its like a routine system check
Posted on Aug 04, 2008
  • 236 Answers
SOURCE: Yamaha dsp-A1000 5 ch Amp
if you wanted to use your receiver as your controller and source then try to find out the receivber has got a bridge (jumper) between the pre-amp stage and the power amp stage. if your receiver does not have that, then you can just connect your receiver tape record out to one of your DSP inputs. subwoofers, the DSP has got a sub woofer out connector. you can use that (RCA type) to your sub woofers. put in series because DSP has got only one output for sub. or, you can connect your subs directly to the mains speakers, parallel connections. maybe one sub to your left and the other to your right channel.
  • 85 Answers
SOURCE: where i could find the
A common problem on these amps ie no sound is due to dirty switches and tone contols,amp face needs taking off and contact cleaner needs spraying into all controls...
Posted on Jan 15, 2009
Grubhead
  • 4872 Answers
SOURCE: yamaha dsp a1000 two remotes and both don't work
Are you certain they are at fault? It could be that the Yamaha isn't responding, due to a faulty remote censor. Try a good universal first to be certain, before attempting repair of the remotes.
Posted on Nov 18, 2009
petraman7
  • 1175 Answers
SOURCE: where can i get a new selector switch
encompassparts website
Posted on Aug 17, 2010
Own a Yamaha DSP-A1000. Center channel "died" this week. Everything had been working for years. Suddenly, the center channel stopped working (very obvious in DSP fields for Home Theater). Any...
If you run through the setup and certify it knows about the center channel first, then test it with tiones, then maybe swap the center speaker with another one you might come to an answer.
May 13, 2011 | Yamaha DSP-A1000 5-Channel Amplifier
Where can I buy a replacement selector switch for the Yamaha RX-750 Receiver?
Hi,,,
Try encompass parts on-line 1st If not there , try yamaha direct
Yamaha Parts Department at (714) 522-9011
PLease rate my help.
Thanks
Aug 24, 2010 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha dsp a1000 two remotes and both don't work at all any fix for them
Nov 16, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Problem with Yamaha dspA1000
Be sure you are using the AUDIO OUT on the vcr then going into a AUDIO INPUT on the DSP A1000, this will allow the DSP A1000 to amplify the audio line level.
Jan 31, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Where i could find the schematic diagram of yamaha amps model DSP-A1000
Jan 14, 2009 | Yamaha DSP-A1000 5-Channel Amplifier
Rx v2095 receiver - No sound from either front main speaker
I have had similar problems on a Denon. I suspect your DSP needs repaired and/or replaced. Need to contact authorized Yamaha repair shop or a competent local repair facility. I have a Yamaha RX-V2092 which is similarly designed. I have had it for 10 years. Hope this helps.
Nov 29, 2008 | Yamaha RX-V596 Receiver
Yamaha Dsp-A1000 5 ch amp Bought a used amp will be hooked to an awia reciever and speakers also have two subwoofers need help to install correctly witch connections to use
Jul 24, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Dsp-a1000 dead
Jun 22, 2008 | Yamaha DSP-A1000 5-Channel Amplifier
Effect off
Dear Zforce, The Yamaha DSP A1000 has three different options of on-screen display. Try using the On-screen button on the remote control in order to remove the disturbing display. If this fails or if your remote control malfunctions then you should contact Yamaha for further assistance.
Oct 31, 2005 | Yamaha DSP-A1000 5-Channel Amplifier
Yamaha DSP-A1000 5-Channel Amplifier Logo
614 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
