Question about Panasonic Lumix DMC-LZ2 Digital Camera
PC will not recognize memory card
I have some photos that I recently took that may be used in a lawsuit.
My camera will NOT connet with my pc using SD Viewer software -- prompt = Memory card not located.
I then took the darned memory card into a local drug store, and tried to download images to a cd. Apparently, there are some video files on the camera. HOW CAN I FIND AND DELETE THE VIDEO MEDIA, SO THAT I CAN DOWNLOAD THESE PHOTOGRAPHS?
Thanks, Dawn
  • ashley012988 Jan 03, 2009
    I insert my sandisk 4bg and it freezes my comp as soon as I take it out the comp goes back to normal. The disk has also been read on a friends laptop but for some reason does not work on mine. help needed! plz!
  • 95 Answers
Even though the card has video files on, this should not prevent you from seeing the still pictuers. Try and open my computer and open the removable drive to view the pictures.
Posted on May 31, 2008
I have a panasonic lumix DMC-FS7. Used it for many years with 4GB SD card insitu. Recently took some precious photos and am trying to copy photos from camera to PC. When I plug the camera into my PC it...
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Feb 04, 2013 | Panasonic Lumix DMC-FS7 Digital Camera
My computer quit reading the card or the camera, so I can't get pictures from the camera onto my computer
Try removing theSD memory card from your camera and inserting the SD memory card into an USBmemory card reader then connect the USB card reader into the USB port of aworking computer. The computer will see this USB card reader and SD memory cardas an external storage device. You can open the camera photo folder and copythe photos to your computer.
Apr 13, 2012 | Nikon Coolpix S4000 Digital Camera
Pentax E85 PC connection fail
Put the card into the camera, use the "Copy" command in the Edit menu to copy the two photos onto the memory card, and then transfer the photos to your computer as you usually do from the memory card.
Apr 01, 2012 | Cameras
Took some photos without memory card. The photos are in the camera's memory, how can I transfer those photos into a memory card?
There are some solutions, but the most easy one is:
1. Take the SD card out of the camera and connect it to the pc to transfer the images. After that, put the SD card back into the camera.
2. There is a menu option in the SP800uz to change the memory to Intern, Extern (SD) and Auto (default). Change it temporary to Intern, connect the camera to the PC and transfer the images. Set the setting back to Auto (or else) afterwards.
Sep 11, 2011 | Olympus SP800UZ Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I have a canon powershot sx200 IS and I recently went on vacation and took a lot of pictures using teh SD memory card provided with the camera. For some reason, after almost filling the card I received a...
The likely reason this keeps happening is that these cards weren't formatted in the camera when you first got them. However, don't do so just yet as formatting also erases the card. If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones. Now AFTER you've recovered the photos, format the cards IN THE CAMERA USING THE CAMERAS FORMAT FEATURE. Look for it, it's located under the "tools" menu (look for the item stating the card's memory capacity). This should rejuvenate both cards, and prevent reoccurrence.
Aug 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
My Kodak C633 is not seeing/recognizing the SD card.
The reason this problem occurred is that you likely never formatted the card. The card will work fine in the beginning for the first few shots, but eventually will corrupt. But don't format that card just yet as it will erase the card.
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
You will need to use a flash card reader with this software. If you don't have one, get one, they're very inexpensive these days:
AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Jul 05, 2009 | Kodak EasyShare C633 Digital Camera
I want to download my pictures from my sanyo 770 digial to my p.c
2 Options:
1. Your camera probably came with a USB cable. If so you need to connect that cable from your camera to your PC and turn on the camera. Your computer should automatically recognize that you've plugged it in and should run a "wizard" that will walk you through importing those photos.
2. Your PC may have a "multi-card reader" this is a series of slots that accept different sizes/types of memory cards from cameras etc. Your camera has a memory card that you can remove and place into one of these slots. Again once you've plugged in this memory card you should again get the wizard asking you'd like to do.
Jun 19, 2009 | Dell Computers & Internet
Pictures not loading to computer
It sounds like you don't have software on your PC that will recognize the camera when connected. I am going to recommend that you do not use the camera to upload photos. It is better practice to use external (SD) memory cards and remove them from the camera to upload. You can use a USB SD reader or purchase SD cards with a built-in USB interface. You should be able to see a new drive when connecting the SD card to your computer; then all you need to do is copy over the images. One advantage is that you will save camera battery while uploading because you dont need the camera at all. It also allows you to take images with you without taking the camera, i.e. school or work. I hope this helps...californiajones7889e54.jpg67432f4.jpg4db3d64.jpg
Mar 09, 2009 | Kodak EasyShare C875 Digital Camera
Sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Jan 15, 2008 | Cameras
Panasonic Lumix DMC-LZ2 Digital Camera Logo
77 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
