Question about Apple iPhone 3G
IPhone 3G - there is a new, tiny icon next to the battery charge indicator (extreme upper right corner). It looks like two triangles, one atop the other, pointing to the right. What is this? Does it mean something's wrong? It is visible all the time. Thank you!
    Genius:
  • 1,478 Answers
If the icons are not disturbing the normal operation of the iphone, no cause for alarm, but if they are, you may have pressed a function on the iphone menu before it can indicate those icons, check your user manual to see what the icons represent. Also, i will advice you reset the iphone, you can follow this procedure or procedure stipulated out on the manual on how to reset the iphone. Press and hold the power and menu button simultaneously at least for 20 secs,then release when the iphone turns off and restarts automatically.
If you are able to reset the iphone, those icons will disappear.
Take care..
Posted on Sep 13, 2010
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
What is the small arrow icon in the top right Corner of my iPhone? It turns purple When using an app
It's an indication that the app that you're using is locating your current location. It's a feature of new iOS versions 4.0 and up.
Feb 19, 2011 | Apple iPhone 3G Black Smartphone
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Iphone wont charge
plz change ur baterry ur charger
Sep 15, 2009 | Apple iPhone Smartphone
My iphone wont charge from the computer or my wall charger
If you are using the same cable connected to the mains and the PC then it would indicate that you have a faulty USB cable, especially since it charges in the car.
Aug 31, 2009 | Apple iPhone 3G
Icons tiny using iphone theme download
It looks like you tried to load a theme that was not for the touch hd. Make sure the theme is meant for a wvga screen (480 X 800 pixel). If it is not, it will not look right on the touch hd.
May 09, 2009 | HTC Touch HD Smartphone
Touch screen of phone on my iphone isnt working
Looks like your iPhone may be damaged.
Have you dropped it?
What kind is it the IPhone-iPhone 3G?
If you can give us your serial number we at Apple will see what we can do.
To obtain your serial number go to settings click general and go to about the first part o the iPhone.  Thank You. Steve A
Dec 22, 2008 | Apple iPhone Smartphone
IPhone 3G Battery Life
All of the iPhones have the ability to connect to an external battery, a charger, or any computer with a USB port. You only need a cable. Does your Treo charge from any USB port? And carrying a cable in your bag is no harder than carrying an extra battery.
I don't think you'll ever see a replaceable battery in an iPod or iPhone. It would make the device too big and it would reduce the battery life--that's right, battery life is worse with a removable battery because the battery has to be smaller. However, you can be sure that Apple will continue to push the chip makers for lower power chips
if this can't help you then add an comment i"ll solve it for you
Oct 13, 2008 | Apple iPhone 3G
Indicator unknown
the is the bluetooth icon.
Kinda looks like two side ways triangles stacked on top of eachother. GO into your settings and turn it off if you dont wantto use it. Bluetooth will drain a battery.
Jan 18, 2008 | Motorola Mobility RAZR V3
Apple iPhone 3G Logo
51 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
