This morning I turned on my Magnavox plasma screen 42MF230A/37 and I heard a strange pop. When the picture came up there was a large black jagged spot covering about a third of the screen on the left side. Is this something that can be fixed or is the TV dead. It is almost 5 years old.
  • Televison & ... Master
  • 1,213 Answers
Chances are real good, that you have a blown capacitor. When you open or lift the back cover, you will find one or two capacitors that are bulged! These capacitors will need replaced. I would guess one of them will be 25 volts at 1200Mf. There will be another very close by. I do not recall its value at this time. It will need replaced as well. Find a TV tech or even an electronic hobbiest to check all the nearby capacitors. You may be able to save this TV. Give me a few hands and thanks for asking!
Posted on Sep 13, 2010
My magnavox model# 42mf230a/37 tv turns on I get good sound and picture but it has a 4inc black line onleft side edge of screen
Black lines on Plasma TV are cause by either the buffer boards or the logic board. OR your screen is bad. the only way to find out is the replace the boards. I would start with the Buffer boards. The buffer boards are located on the bottom of the screen attached by ribbon cables to the screen. look at the bar and replace the board that lines up with it. You can find parts fro this TV at www.interliquidparts.com You have to get the actual part number from the part on your TV to get the correct one.
Jun 13, 2011 | Televison & Video
Magnavox/samsung 42MF230A/37 plasma t.v. turns on, no picture.
the only way to check it is to change out boards. the "sugar cubes" are ceramic resistors and should get hot. if you have the correct voltages on the p/s then you will need to replace both the y and z boards. better off buying a new tv. consider letting a professional tech. check it for you, this is not something to be tried unless you know what you are doing. if you really want to do it yourself get the service manual and a voltmeter.
Mar 24, 2010 | Televison & Video
42' plasma magnavox model # 42MF230A has no picture and no sound
I had the same problem with an Insignia 42" 1080p. Turn off the tv power and disconnect all cables (i started with power cable, then HD cables then HDMI). Wait 30 seconds with nothing plugged in, then I plugged everything back in (in reverse order) and it works fine.
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
I have a magnavox 42mf230a/37 with black screen
more that likely your set got a serge and bleew a couple of capacitors in the power supply esay to find they will have dome on the tops from venting
Sep 17, 2009 | Televison & Video
Horizontal lines on screen
well if they run all the way up and are on every input through then menu the panel is NG, some panels are around $500 now.
Jul 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Magnavox 42MF230A/37 Plasma TV should i fix it? ?
you will need that part to repair yours. i recomend using the heatsinks from yours. u need to check the FETs on the board that drives that one before u power it up, or u could damage the new part.
Dec 05, 2008 | Philips Magnavox 42MF521D/37 Television
Magnavox plasma tv model 42mf230A/37
I guess they are just built to fail. Mine was less than a year old, but they are sending me the exact same unit. Uggghhh
Mar 29, 2008 | Televison & Video
42 inch magnavox #42mf230a/37
One of the driver IC'S has gone bad. Need to replace just the driver IC or the board that the IC is on and that should solve your problem. If that doesn't do it, then the BAD NEWS IS THAT THE PANEL IS BAD. Replacement is you only option then. Good luck. GURU JAY.
Mar 16, 2008 | Televison & Video
I have a plasma tv need help
Sounds like panel is bad or driver ic is bad on the board directly below the black line. Good luck on the repair. Any questions, we can do a chat and go from there. GURU JAY
Mar 14, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
