Question about Sharp LC-42D43U 42 in. LCD HDTV
When I turn the set on a picture only lasts a moment then the power lite and theOPC lite flash, both together then the OPC then both... what should I do?
  • Sharp Master
  • 8,457 Answers
Unplug,replug tv back hour later.To let the tv to reset it self back to factory.The tv should work now.Not than the Tuner board is dead,that the board that,where the incomming broscasting signal cable plug into it.Tries websites like a Shopjimmy.com,Ebay.com to buy a Tuner board for the replacement.
Posted on Sep 13, 2010
Sharp Aquos LCD TV Error Codes power flashes twice and opc flashes 5 times - What does this mean?
Sure - but you need to find out what the new error codes stand for and be guided accordingly. You might want to check on the Sharp web site.
Your t con board might also have gone south.
Jun 10, 2016 | Sharp LC-52D62U 52 in. LCD HDTV
Model LC-465B57U flashing power light and opc light
Hi Tracy,
It appears your TV is not sequencing properly. By the order given in your instructions with the controller you are tuning, continue with a code until it satisfies .
Press setup- blinks twice. Enter TV manufacturer code- press enter. Light should flash once. Press on . After it works . Go through all the functions. Up- Down, loudness, channels,& on -off .
Fare .Well.
Dec 12, 2014 | Sharp Televison & Video
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Thethe tv will not come on and power and theopc is flashing.
Ok This is how to troubleshoot the TV, there are lights on the front and you are mainly concerned with two of these lights (the power light and the OPC light). I) If non of the lights come on then this is a AC Power failure (There is a loose connection or you need to check the Power/Inverter unit or the Main unit) II) If the power light is blinking at a rate of one blink per min and the OPC light is off (then there is a CCFL backlight problem) III) If the power light is blinking at a rate of two times per min and the OPC light blinks at a rate of one time per min (13V/UR10V failure you need to check the Power/inverter board or the main board). IV) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of two times per min (3.3V Main Failure check power/inverter board or Main board). V) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of three times per min (UR6V failure check power/inverter board or Main board). VI) If the power light is blinking at a rate or two times per min and the OPC light blinks at a rate of Five times per min (Panel 5V failure check LCD control unit or control panel).
Sep 07, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
I have a sharp 37" lcd tv,model # lc37sb24u. no pix or sound, power lite comes on about 10 seconds then power and opc lites alternate on and off. thanks RON
This problems very common in Sharp LCD tvs.The Tuner signal board have problems,every times the power LED,OPC LED lites up,just push the power button on again,wait see if the LCD backlight lite up and works,not the Power lite and the OPC lite LEDS flashes again.You,just have to push the power button again,sometimes u have to push the power button at least 6 or 7 times to get the Power LED stable,and then LCD backlight,come on than the tv work.Not sure,but if the Power and OPC lites keep flashing,after u pushes the power button at lest 10 or 12 times,and the LCD backlight dosen't come on and the tv don't work.I think,it time to change the Tuner board is completely dead.I have a Sharp LCD tv, I do this everytimes pushing the power button at least 3 or 4 than the power LED stable,and the LCD backlight come on than the tv work.Not a plaw in the power supply like those capacitors in many LCD models tvs,but some included Sharp Tvs is the Tuner signal board is not very good in design,use the tv awhile the Tuner signal board have problems recieving the power to it Tuner board components.
Apr 15, 2010 | Sharp LC37SB24U 37 in. LCD TV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Set up only visible for 2 seconds, then black - Aquous lc-37d43u
Unfortunately I can promise you that you CANNOT repair this. Your power and opc lights coming on, but the tv is not coming on. That is a issue within the tv. Give sharp a call and they will have somebody come fix your tv free of charge, if they cant fix it, they will replace it for free. That is the only thing you can do. Sorry bro
Dec 10, 2008 | Sharp LC-37D4U 37 in. LCD Television
Sharp LC-42D43U 42 in. LCD HDTV Logo
190 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
