Question about Jenn-Air JS48SEFXDA Stainless Steel Side by Side Refrigerator
Jenn Air 48" Built In Not Cooling
We have a refrigerator with an intermittent cooling problem. It will go up to 70 and then back down eventually to 34 (freezer goes 23 to 1). We have had repairmen out who have replaced the cleaned the coils, replaced the condenser and the compressor, and the last time cleared debris from the old compressor repair and replaced the drier. It has been down off and on for 3 months. We keep getting told it is fixed only to lose $'s of dollars of food.
  • kramerdawg Sep 03, 2008
    refrigerator not cooling and the refrrigerator lights do not shut off even though the refrigerator door is closed..
    Genius:
  • 1,073 Answers
The company that replaced the parts also should have changed the low side line and capiliary line it comes together as one unit
the capiliary line is partialy restricted
Posted on May 16, 2008
  •  Pleazer Appliance
    Pleazer Appliance Jan 23, 2011
    This is correct, the heat exchanger, compressor, muffler, and drier all need to be replaced at the same time. Once the system is opened the remaining parts,"condenser, evaporator" need to be blown out with nitrogen to satisfaction. With the compressor kit comes a new control board, and instructions to re charge the system at a slightly lower amount... This is an extensive job, but when done right will yield success. I have done many....
Seeking normal temperture range for 10 cubic foot refrigerator
Refrigerator temperatures should be between 34 to 38 for good cooling. Freezer temps should be from 0-15 to keep ice cream fairly hard
Mar 25, 2014 | Jenn-Air JCD2290HES Side by Side...
Fridge is warm, then cooling again
hi ben.ummmmmm.i dont think so.possibly blocked condensing unit. clean it first.good luck Ali
Jun 25, 2012 | Frigidaire Refrigerators
My Subzero 650 does not stay on 34 degrees consistently. It is not now and I have turned the unit off for 15 minutes but to no avail. It has done this before but after a 36-48 hours it is back to 34...
aHi,
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 23, 2011 | Sub-Zero Refrigerators
Freezer side works, but refrigerator side is warm
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Jenn-Air 48" Side-By-Side Built-In...
My jenn Air refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
erwwer
Jun 10, 2010 | Jenn-Air JCD2389G Side by Side...
We have a built in Jenn Air refrigerator Model #JS48FSDBDA
Remove the kick plate at the bottom, then you will see the head of a bolt this raises and lowers the wheels, I'm assuming your wheels are up turn bolt clockwise. Thier will be a bolt on each side. The wheels are contained inside of a sheetmetal housing. Once the wheels are down you will be able to roll it back and forth. Go to www.appliancehelponline.com enter your model # and it will bring up a diagram of your unit. The diagram needed is the one for the cabinet. Hope this helps.
Mar 05, 2010 | Jenn-Air 48" Side-By-Side Built-In...
Jenn-Air JCB2389GRS Fridge not cooling properly
heatman101
puiodf
Mar 15, 2009 | Jenn-Air JCD2389G Side by Side...
Fridgerator no longer cooling
take off back panels in freezer. you will find ice built up. i used hair dryer ,mine was a blook of ice.
Jan 26, 2009 | Jenn-Air JCD2295HES Side by Side...
We just had a repairman out for the same exact problem. What he discovered ours was is that the lights intermittently stay on with the door closed. Test yours like this. With the door open, push the switch that switches it off and on off and on several times. Chances are you'll see that even with the switch depressed the lights are on. If that's the case he says it's one of the relay boards. There are four and the repairman will need to check to see which it is. Hope this helps. If this is the case for a temporary fix you can open the freezer door slowly close the fridge door while peeking through the crack to make certain the light is off.
May 15, 2008 | Jenn-Air 48" Side-By-Side Built-In...
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Jenn-Air JS48SEFXDA Stainless Steel Side by Side Refrigerator Logo
225 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
