No connection i have uninstalled the miniport device, but there is still no connection. the two little computers in the lower right hand corner are still not connected. It says unidentified network linksys when i put the mouse on the computers. When i go into the network and sharing center there is an x on the line going from the unidentified network and the internet. The access is local only, the wnc is linksys, and the signal strength is excellent. Please advise me on anything.
    Problem Solver:
  • 9 Answers
If you cant connect to the internet you camn go to Start, Rum and type CMD, when the black screen aprears type in ipconfig /flushdns and enter then type ipconfig /renew
Posted on May 17, 2008
Garmin 1450Lmt is not able to connect satellite
if you are not getting any bars in the top left corner of the screen, turn the device off and press and hold in the lower right hand corner of the screen, while holding the lower corner turn the device on, when you see the screen start to turn on let go of the power button and continue holding the lower right. it should ask you if you want to erase all user date and then you will select yes. be advised this will also erase any saved waypoints/favorites you have.
Sep 05, 2011 | Garmin nuvi 1450 GPS Receiver
TATA PHOTON+ Dialer Error 720: A connection to the remote computer could not be established. You might need to change the network settings for this connection. Can anyone fix this problem??? I'm using...
f you are experiencing this when trying to use Dialup Networking (ThinkPad Modem) or Verizon VZAccess Broadband, the following may be useful. Note, the solution involves modifying the registry on XP so it is not for the faint of heart.
Note that a key symptom of this problem is that the modem connects and then disconnects just after trying to register the computer on the remote network.
Step 1: Uninstall the WAN Miniport (IP) and WAN Miniport (PPTP)
IMPORTANT: This procedure contains information about modifying the registry.
Before you modify the registry, make sure to back it up and make sure that
you understand how to restore the registry if a problem occurs. For
information about how to back up, restore, and edit the registry, click the following
article number to view the article in the Microsoft Knowledge Base: 256986
(http://support.microsoft.com/kb/256986/EN-US/) Description of the Microsoft Windows Registry
SYMPTOMS
When you try to use a dial-up connection to connect to your Internet Service
Provider (ISP), you may receive the following error message during the
"Registering your computer on the network" portion of the connection
agreement:
Error 720 - the connection attempt failed because your computer and the
remote computer could not agree on PPP control protocol.
Additionally, when you view the devices in Device Manager, you may notice a
yellow exclamation mark (!) over the icon for the WAN Miniport IP (#2) device.
CAUSE
This issue may occur if the TCP/IP protocol has become unbound from the
dial-up adapter, or if a conflict is created when a second WAN Miniport IP
device driver loads.
RESOLUTION
To resolve this issue, uninstall the WAN Miniport IP and PPTP devices.
To do so, follow these steps:
1. Right-click My Computer, and then click Properties.
2. Click the Hardware tab, and then click Device Manager.
3. On the View menu, click Show hidden devices.
4. Under Network adapters, you will see WAN Miniport IP
devices. If a WAN Miniport IP device is listed, continue to the
following step. If no WAN Miniport IP device is listed, go directly
to step 16.
5. Click Start, click Run, type regedit in the Open box, and then click OK.
WARNING: If you use Registry Editor incorrectly, you may cause serious
problems that may require you to reinstall your operating system. Microsoft
cannot guarantee that you can solve problems that result from using Registry
Editor incorrectly. Use Registry Editor at your own risk.
6. Locate the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-
08002BE10318}
7. On the Registry menu, click Export Registry File, type backup-key in
the File name box, and then click Save.
Note You can restore the changes that you make to this registry key. To do
so, double-click the backup-key.reg file that you saved.
8. Click each of the registry subkeys under this key, and then view the Data
column of the DriverDesc value to determine which of the subkeys
corresponds to WAN Miniport (IP). For example, the 0005 subkey.
9. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) or
WAN Minport (PPTP); (for example, right-click 0005), and then click
Delete. Click Yes to confirm that you want to delete the key.
10. Quit Registry Editor.
11. Right-click My Computer, and then click Properties.
12. Click the Hardware tab, and then click Device Manager.
13. On the View menu, click Show hidden devices.
14. Under Network adapters, right-click WAN Miniport (IP) and then click
Uninstall. Click OK to confirm that you want to remove this device.
15. Repeat for the WAN Miniport (PPTP).
Step 2: Reinstall the WAN Miniports
1. Find netrasa.inf in c:\windows\inf
2. Make a copy of the file and name it netrasa.inf.save
3. Open the orignal copy of netrasa.inf and place a semicolon
in front of the line that starts "Excludefromselect=\" and
and continue with all follwing lines and then end with
"MS_NdisWanNbfIn,MS_NdisWanNbfOut" under the [ControlFlags]
section. (all lines between)
Step 3:
1. Start a Add new hardware session (from Control Panel) and choose
that the hardware is already installed. Choose to "Add New Hardware"
and then select "Network Adapters" followed by "Microsoft" and then
both the PPTP and the IP Wan miniport one at a time.
(NO need to reboot between these steps)
2. After you finish both then reboot.
3. Select Start -> Run and type: netsh int ip reset c:\resetlog.txt
(For details, see http://support.microsoft.com/kb/299357)
4. Reboot and try your connection.
5. Delete the modified netrasa.inf and rename the original (which was saved as netrasa.inf.save) back to netrasa.inf
Jun 30, 2011 | Sony Computers & Internet
I bought my printer an hp 3050 wireless printer and mistakingly insatlled the wirelss part of it. I would like to uninstall it but can not find out how to do it. Can you helpme.
Hi there!
(For Windows only) To switch the type of connection from wireless to USB conn you can do these steps:
-Click on START or the orb looking window icon on the lower right hand corner of your computer screen. -Click on Programs/All Programs -Click on HP (just the HP folder) -Click on your HP model folder (HP deskjet 3050) -Click on Add a device. It will ask you to select the connection type -Select USB. It will then ask you to connect the USB cable and wait until you see a Congratulations page to make sure that the product was installed successfully -Try to print a test page.
Uninstall from All Programs -Click on START or the orb looking window icon on the lower right hand corner of your computer screen. -Click on Programs/All Programs -Click on HP (just the HP folder) -Click on your HP model folder (HP deskjet 3050) -Click on uninstall.
Uninstall from CD -Insert the CD that came with the printer -when you see the main Installation Menu click on Uninstall
Uninstall from Control Panel -Click on Start -Click on Control Panel -Click on Add/Remove Programs or Programs & Featurs or Programs -Look for the HP programs listed (listed alphabetically) -Click on the HP Program you want to remove and click on Remove or Uninstall
*It may ask you to restart the computer so it would be better if you will save importand documents before uninstalling
Hope this helps!
Jun 12, 2011 | Office Equipment & Supplies
Dial up connection ends in error code 720, can't connect to the internet. Using a back-up pc that is terribly slow. would like to fix pc.
Error 720 - the connection attempt failed because your computer and the remote computer could not agree on PPP control protocol.
To resolve this issue, uninstall the TCP/IP protocol, remove the second WAN Miniport IP device, and then reinstall the TCP/IP protocol. To do so, follow these steps:
  1. Uninstall the TCP/IP protocol. To do so:
    1. In Control Panel, double-click Network and Dial-up Connections, right-click Local Area Connection, and then click Properties.
    2. Under Components checked are used by this connection, click Internet Protocol (TCP/IP), and then click Uninstall.
    3. Follow the on-screen instructions to uninstall TCP/IP.
    4. Restart the computer when prompted, but click No if you are prompted to allow Windows to enable a protocol.
  2. Right-click My Computer, and then click Properties.
  3. Click the Hardware tab, and then click Device Manager.
  4. On the View menu, click Show hidden devices.
  5. Under Network adapters, there should be no WAN Miniport IP devices. If a WAN Miniport IP device is listed, continue to the following step. If no WAN Miniport IP device is listed, go directly to step 16.
  6. Click Start, click Run, type regedit in the Open box, and then click OK.
  1. Locate the following registry subkey: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002BE10318}
  2. On the Registry menu, click Export Registry File, type backup-key in the File name box, and then click Save.
    Note You can restore the changes that you make to this registry key. To do so, double-click the backup-key.reg file that you saved.
  3. Click each of the registry subkeys under this key, and then view the Data column of the DriverDesc value to determine which of the subkeys corresponds to WAN Miniport (IP). For example, the 0005 subkey.
  4. Right-click the subkey whose DriverDesc value data is WAN Miniport (IP) (for example, right-click 0005), and then click Delete. Click Yes to confirm that you want to delete the key.
  5. Quit Registry Editor.
  6. Right-click My Computer, and then click Properties.
  7. Click the Hardware tab, and then click Device Manager.
  8. On the View menu, click Show hidden devices.
  9. Under Network adapters, right-click WAN Miniport (IP) and then click Uninstall. Click OK to confirm that you want to remove this device.
  10. Reinstall the TCP/IP protocol. To do so:
    2. Click Install.
    3. In the Select Network Component Type dialog box, click Protocol, and then click Add.
    4. Under Network Protocol, click Internet Protocol (TCP/IP), and then click OK.
    5. When the protocol is installed, click Close.
  11. Reset the modem by turning the power off and then on, or for an internal modem, restart the computer.
  12. Test your Internet connectivity.
May 02, 2010 | Acer Aspire T650 PC Desktop
Brand new aspire 5732z laptop comes up with code 31 fault on virtual wifi miniport adaptor says it has driver fault,what can I do
The Microsoft virtual wifi miniport adapter is a new feature in Windows 7, Wireless Hosted Network:
About the Wireless Hosted Network
This device is just a virtual device and it should not affect connecting the wireless network with the physical wireless adapter.
Hence, I’d suggest you to uninstall and re-install only the wireless network adapter drivers from Device manager and check if that fixes the issue.
Before uninstalling the drivers from the device manager, make sure you have a backup of the installation files.
It’s a good idea to create a restore point before uninstalling the drivers. A restore point is a representation of a stored state of your computer's system files. You can use a restore point to restore your computer's system files to an earlier point in time. Restore points are automatically created by System Restore weekly and when System Restore detects the beginning of a change to your computer, such as when you install a program or a driver.
Create a restore point
http://windows.microsoft.com/en-US/windows7/Create-a-restore-point
Visit the manufacturer’s website, download the latest wireless drivers and save it on your hard disk.
To uninstall the wireless connection from Device Manager,
1. Click Start, type Device Manager in the Start search box and hit Enter.
2. Locate Network adapters and expand the same.
3. Select the wireless connection, right-click and select Uninstall.
4. Restart the computer, if prompted.
Drivers should get installed automatically after restarting the computer.
Now, you may install the latest wireless drivers and check if that fixes the issue.
Hope this helps
Apr 20, 2010 | eMachines eMD620-5133 Notebook
I have exclamation marks on wan miniport sspt and wan miniport (network monitor)#2,i am having problems with my desk top (vista)how do i solve these problems
An exclamation mark means the driver is not installed correctly or the hardware is not being started right. In device manager, try right clicking the device and clicking uninstall, then click scan computer in the upper toolbar of the window to reinstall the WAN Miniport
Dec 30, 2009 | Evesham Computers & Internet
400GB Freecom external hard drive stops functioning itself.
I assume you are running windows operating system. You need to uninstall all your usb devices. Go to computer manager/device manager and select all USB devices and unistall them. Go to the start menu, click on run type compmgmt.msc. Find all your USB devices on the right side. Follow the instructions for each device to uninstall them by double clicking and then select uninstall. once you uninstall, click on the icon to scan for hardware changes located on the sub menu. Your operating system should recognize new hardware or reboot and the operating system should install them automatically again. After you reboot, logon do not connect the harddrive until you are logged in completely. The operating system should recognize a new device and install it automatically. I hope it helps.
Mar 09, 2009 | Computers & Internet
Sound loss to PC computer speakers after a Systems Recovery.
First, check that the speaker icon in your system tray, (lower right hand corner) is not muted by right clicking on it and selecting volume control. If not muted, goto My Computer, right click and select Properties, Click the hardware tab then device manager, left click on the + next too Sound, right click on the device that appears and select uninstall, once it is uninstalled, restart your PC. Let me know if that works.
John
Nov 25, 2008 | Logitech Z-560 Computer Speakers
Network adapter
Okay, thanks for that. Usually, the easiest way to repair a Code 10 error is to simply uninstall the device, then allow Windows to install it again. If you have an installation or drivers disc, this is good to have on hand, but it's possible that Windows may be able to automatically install it without requiring one.
To uninstall the device, simply right click on it in the devices list, select Uninstall, then restart Windows. When the computer restarts, it should automatically detect the hardware and attempt to install it. If it cannot find the driver without requiring a disc, you'll need to supply the disc that contains the drivers for the WAN miniport so that it can install it for you.
May 11, 2008 | Computers & Internet
Open Questions:
Toshiba Virus Removal ' Remove Toshiba Virus - DataAlign ' Call +1888784-9316 Toshiba Corporation is a Japanese multinational company that is headquartered in Tokyo. It produces products and services like information technology, communications equipment and systems, electronic components and materials, power systems etc. Toshiba products are innovative and cost efficient which provides best solutions for home or business use. Toshiba has become the world's seventh largest IT Company which launched its first laptop in 1985. All Toshiba products have the best qualities like high efficiency in very affordable pricing, innovation at its best, ultra- portability with faster working laptops and desktops. As known by everyone, every Toshiba user require good Toshiba Customer Care and thus requires a good customer support. Likewise, Toshiba laptops also require a reliable support for the proper working of Toshiba laptops and desktops over a longer period of time. Dataalign provides best in class Toshiba Tech Support exclusively for the Toshiba customers. Dataalign tech support is provided by the highly knowledgeable and expert technicians who have years of working experience in this field and these tech support engineers have been particularly trained to be able to solve the issues related to Toshiba products. Toshiba Support of Dataalign has following features: 1. Slow speed issues are resolved. 2. Toshiba support technicians of Dataalign analyze the issue very carefully and follow proper trouble shooting steps to get to the real cause of issue for properly suitable resolution. 3. Blue screen of ***** and other errors are resolved. 4. Issues like virus, malware, spyware is resolved accurately. 5. Tech support experts providing Toshiba Support to the Dataalign customers have years of experience in the field of providing helpful assistance to customers with accuracy. 6. Dedicated staff with lots of knowledge makes the support team of Dataalign the best. 7. Customer satisfaction is taken care of every time. 8. Highest productivity is ensured after services to Toshiba laptops. 9. Resolution is provided over remote access so that Toshiba customers can witness the issue and the overall process of resolution applied. 10. Toshiba Customer of Dataalign works 24/7 and 365 days a year. For any kind of help in Toshiba products contact on the Toshiba Tech support number of Dataalign :- +1888784-9316
May 23, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
