Question about Dometic Rooftop RV Air Conditioner
My rooftop ac "lets the smoke out" when i turn it to AC but the fan runs fine without smoking. What should i look for?
  • Dometic Master
  • 43,501 Answers
Depending on the humidity and temperature it will "smoke" but the smoke is actually just water vapor and just means that it is working very well....I think that is what is happening in your case...I would not worry about it...
heatman101
Posted on Sep 13, 2010
RV. when furnace is turned on , fan on rooftop AC unit runs continually
i would say its the relay board or communication cabl between stat and board.
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Engine smokes with AC on
Check if it is smoke or steam, if it is smoke do not start the car, if it is steam disconnect AC and go to a mechanic.
Jul 23, 2008 | 1999 Nissan Sentra
Fan smokes, fan runs when ac on
your fan is suppose to run when ac is on if it is smoking check to see if there is anything obstructing it you can do this with the car offf and battery disconnected turn the fan with your hand and see if it moves freely if it turns hard you need a new fan hope this helps
Jan 13, 2014 | Dodge Nitro Cars & Trucks
Acadia white smoke, high temp and fan won't come on
Do you have an extended warranty ?
Usually white smoke from the exhaust means the engine is burning coolant thru a blown head gasket or intake gasket.
You should also be low on coolant in the radiator.
Apr 30, 2013 | 2008 GMC Acadia
5.3 Litre engine sarts running rough when AC is on & white exhaus
the fan coming on is a switch which is easly fixed ,but the white smoke is water thats for sure ,iam wondering in the ac condensate drain pipe is somehow running into the inlet air intake ---how i honestly dont know as in all truthfulness iam in spain so never seen under the bonnet of one.How its laid out and all that so you will have to have a look yourself and see if iam right
Aug 01, 2010 | 2005 Chevrolet Tahoe
When the car is turned on and the AC is off smoke
you need to check if its smoke or steam your head gasket may be failing and when you have the ac on the fans are helping to cool the engine .check your temp gauge when the ac is off also check if your loosing water
Jun 13, 2010 | 2000 Mitsubishi Galant
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Duo-Therm AC does not work
fan motor is possiblely bad but start with the capistors in the run box on the roof remove cover you will see where all the wires go onto a metal or plastic box depending on age of unit remove acess cover peek inside and see if you see a exploded capistor ie: i see smoke comming out of my ac capsitor are easy to change but they can kill you they store a lot of energy and are dangerous if you are not careful with them
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
Central AC unit sent smell and smoke film
thermostat can short out turning on system a short in wiring will do same --smoke can be from fan or circuit board have a mechanic service the system
Jun 11, 2017 | Carrier Adit 600 Base +24V Phone...
Dometic Rooftop RV Air Conditioner Logo
61 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
