Question about Olevia 237T 37 in. LCD TV
After turning on the t.v., it turns off after 10-20 seconds
  • 4 Answers
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Posted on Sep 10, 2011
  • 11,361 Answers
Do the visual inspection of the power supply module first for bad caps, burnt parts, etc., the the voltage checking.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps
Posted on Sep 13, 2010
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Factors of 100
100=1*4*25=1*(2^2)*(5^2)
1, 2, 5, 10,20, 25, 50, 100
Choose which ones you want to list.
Oct 20, 2013 | Computers & Internet
Is my transmission bad
Keep driving it & you will end up with a big bill
to completely rebuilt the transaxle
At first sign of a trans issue you stop using it,10,20 miles
is all it takes to ruin it
Have a trans shop road test,lift test & you go along for the ride
Dec 13, 2012 | 1999 Ford Contour
I have a Tv Philips model 32PW6506/01 few minutes after that is between 10 and 20 minutes go stand by, then if I press p + start and after 10,20 minutes and goes into standby ...If anyone knows about...
Good day!
Usually that problem is cause of the failing capacitors on the power supply section.
You have to do is open the back cover of your TV and look for the actual image of the capacitor with in the power supply section if it is leak/bulged on the top.Please replaced it with the same type,ratings and value.
Thank you and good luck.
May 08, 2011 | Philips 32PW6506 32" TV
The engine its shaking I switch one of the ignition coil because it look really burn and wasn't working now the shaking still when I start the car and while I drive in 10,20, and 30 miles it feel very...
It sounds like a coil over pack (or two) has/have gone bad. Get a diagonstic check done and that will tell you exactly what cylinder is not firing. Replace the indicated coils and you should be good.
Jan 07, 2011 | 2006 Lincoln Zephyr
Hi there I just bought a crown Victoria and the problem is the car is shaking when I drive ,I'm not sure if it's the spark plugs
you dont give me enough information?at what speed ,10,20 30 40.as you dont tell me what is happaning and when ,im going to hazard a go. tyres pressure wheel alignment,if this fails come back to me with more info.adrian,,,,,,,,,
Aug 16, 2010 | 1994 Ford Crown Victoria
Power Bar has a red light, xbox wont turn on
OK, this is a power supply issue here. you will need to replace the power supply board asap/ it is malfunctioning.
Contact Microsoft for this repair.
Jun 22, 2009 | Microsoft Xbox 360 Console
HP PSC 2355 - always says no paper ? It starts some motors and makes lots of noise but does not pull in the paper. The rollers to the front whir round for ages , then it gives in and says "No paper". I...
There is a paper sensor that senses when paper is loaded. If there are no obstructions you can see then that sensor is defective and the cost to replace it would be more than buying a new printer unless you are an electronics technician. Check your warranty first of course.
Nov 30, 2008 | HP PSC 2355 All-In-One InkJet Printer
3rd gen 8g brand new
check the hold switch is off and try again
if that doesn't work plug it into your computer
Jul 17, 2008 | Apple iPod MA446LL/A MP3 Player
Olevia 237T 37 in. LCD TV Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
