Cannot drop the pump to replace the belt on our maytag washer model #sav5710aww
We have unscrwed the three bolts holding the pump in place, but I am not sure what else is holding the pump on. we need to replace the belt but cannot seem to drop the pump?? any help would be greatly appreciated !
Use a gentle hammer action on all 3 sides where screws go in should come out
Posted on May 17, 2008
Clothes still wet
Usually due to blockage in filter or hose or pump, but may be motor brushes not spinning drum to proper speed
May 09, 2012 | Maytag Washing Machines
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Replace the pump on my washer
If they're star shaped, they're called Torx head screws
Feb 16, 2010 | Maytag SAV5710 Top Load Washer
My 3 year old Maytag SAV5710AWW top-load washer
It is your water pump. If you don't know what you are doing it could be tough.
Nov 20, 2009 | Maytag SAV5710 Top Load Washer
How do i replace the belt
There are four bolts holding the motor to the chassis. Remove the four bolts, slide you hand back along the belt and released the belt from the transmission pulley. Once this is done, turn the motor and pump upside down and you will see the three star screws that hold the pump on. Remove the screws and slide the pump off. If the pump is stuck you will have no choice but to break the pump off and replace it.
Mar 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Belt
ouch this ones a litle complicated, hopefully th eold belt is still connected??? youll need to drop the motor assy 4 1/2" bolts, and after you drop the motor assy, youll need to flip it over and removeth pump with a torx20 wrench ,after removing the pump you can install the new belt. the nreinstall.( put the 2 bolts holding rear of motor back on first, makes it much easier to remoint the front bolts. and watch placemnt of the belt around the pump legs, it makes a difference( which is why i hope theold belt is on, makes it easier to see how it hooks up. good luck
Feb 12, 2009 | Maytag SAV2555A Top Load Washer
Instructions to replace bad pump on Maytag top loader, model SAV5710AWW
hi thanks for the question pull the washer away from the wall you will see a small plate at the back remove this plate pump is there in corner held in there with 3 3/8 bolts remove hoses and remove pump you will get some water drain washer first by gravity please accept and positive feed back is nice thanks the appliance doc
Sep 23, 2008 | Maytag Washing Machines
SAV205DAWW Maytag Washer Belt Replacement Instructions
This is specifically for a Maytag Legacy SAV515DAWW, but may apply to the whole Legacy line.
There is only one drive belt on this washer and it is not accessible directly from the bottom as a pan forms the bottom of the case. All work can be performed through the bottom front panel, once it is removed.
Before one starts, an overview is helpful. The motor for the washer is bounted just behind the access panel. Attached to the shaft at the motor bottom is the drive pully for the drum belt, along with the belt tensioning pully and spring. Below that is the pump assembly attached by three screws in the shafts, which are accessible only from the bottom. What you must do, is remove the pump by unfastening four hex-head bolts, then rotate the motor and pump assembly bottom upwards to the front, so the bottom of the shafts containing the torx head screws fastening the pump are accessible.
While everything is all together it is helpful to notice that the far support for the pump is in almost a direct line with the motor shaft and the tum pully shaft. When you reassemble the components, this vertical pump support must go between the belt. As you face the washer, the tensioning pully will ride on the outside of the right side of the belt.
1. Unplug the washer.
2. Pull it out from the wall, so it may be tilted back at about a 45 degree angle and will not fall foreward.
3 Remove the two hex head screws on the right and left bottom front of the washer. The panel should lift out from the bottom, Two pins hold the top of the panel in.
4. Examine the mechanism as described above.
5. Detach (Unhook) the tensioning pulley spring from the front of the bracket above the pump..
It is not necessary to remove any of the hoses. There is adequate flexibility and slack for replacing the belt.
6. Remove the four hex bolts attaching the galvanized motor bracket to the frame.
7. Rotate the motor back, so the pump bottom faces the front.
8. Remove the three torx head screws in the pump support arms.
9. Detach the pump from the motor. Gently pry it off or gently strike the body of the pump away from the motor with a soft faced mallet.
10. Place the new belt on the motor pully and reinstall the pump, so the leg closes to the tub pulley is inside the two sides of the belt. Reinstall the pump screws in the plastic shafts.
11. Reinstall the motor and fasten the bolts.
12. Make sure the tensioning pulley is to your right of the belt and then side your hands to the rear and slip the belt under the drum pulley and completely around it.
13 Feed the belt onto the drum pulley. I did this by reaching back with my left hand and feeding the belt, coming from the motor pulley, into the drum pulley, then slowly rotating the right side of the drum to me with my right hand.
14 Check to ensure the tensioning pulley is to the right of the belts, then reattach the spring, so the pulley forces the righthand belt to the left.
15. Set the washer upright, open the lid and rotate the drum around twice using your hands. This will help seat the belt on the pulleys and ensure the drum is not stuck.
16. Make sure the cycle switch is pulled out (set to off) and plug the power in.
17. Set on a wash cycle and looking in the bottom , check for proper operation. If the motor appears to be stalling, immediately turn the unit off. Rotate to tub some more by hand and test for operation. If it still doesn't work, see help, your problem is more than just a belt!
18. If everything seems to work, toss in a test load of laundry and pat yourself on the back for being able to save some money!
Mar 24, 2008 | Maytag Legacy Series Top Load Washer
How to replace Maytag Washer belt
I have a model sav2655aww maytag washer. And it needs a new belt but I dont know how to replace it! Can the pump be removed with out removeing the motor ? Also the tub keeps going off center whats with that ?
Sep 03, 2007 | Maytag SAV5710 Top Load Washer
Washing Machines Logo
115 people viewed this question
Top Washing Machines Experts
