Question about Brother MFC-8440 All-In-One Laser Printer
Brother 8440 i have a brother 8440 with a broken adf hinges.where do i get this part?
    Champion:
  • 320 Answers
ONLY FROM A AUTHORIZED BROTHER SERVICE CENTER. ABOUT 59.00 - BROTHER TECH
Posted on Jan 14, 2009
Brother 8820d MFC auto doc feeder does not work...
You need a new hinge so the cover will sit down properly, or paper will jam anyway, but it sounds like there is still a scrap of paper on one of the sensors inside the ADF, you need to look with a flashlight down thru where the paper goes and also look up thru the slot with the ADF lifted.
Sep 11, 2009 | Brother MFC 8820D All-In-One Laser Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
Brother mfc-8440 printer/fax
you need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Nov 13, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Platten hinge broken
Those hinges have been updated by Brother. You need to go to Brother's website and find a local service center.
Jun 17, 2008 | Brother MFC-8440 All-In-One Laser Printer
Can't make a copy
1: power off and power back on. 2: see the original manual for resetting to factory defaults.
May 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
How to replace broken hinge on ADF on Brother MFC-8820D printer
Look at back of machine and at your new hinge, note the screw hole, if you undo both of those on the back of the printer, entire doc feed will come up and out, BECAREFULL just lift A LITTLE is enough to enable hinge base to be free of sockets (many cables attached) and place doc unit slightly sideways on copy glass to enable yourself access to 3 screws that hold hinge.
Jan 05, 2008 | Brother MFC-8840D All-In-One Laser Printer
Adf hinge for mfc 8440 where to buy
Very common fault most Brother dealers carry this item, any service agent should stock, ring brother and ask details of your nearest printer agent.
Oct 20, 2007 | Brother MFC-8440 All-In-One Laser Printer
I need a new ADF (automatic document feeder), where can I get one?
ADF can be bought from a dealer, it has a few cables that need removal so it is a little tricky, it is also a expensive part (approx Aus$200, why are you replacing it, are you sure you dont just need to clean feed rollers or there is also another common fault on these doc feeders, the left side hinge breaks( replace hinge)
here is the brother part number for the adf (complete), you will need to purchase from a autherised brother dealer -
LE8659001  DOCUMENT COVER LGL ASSY
Oct 17, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
130 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
