Aficio 270 functional problems sc390 code - Office Equipment & Supplies
  • Anonymous Apr 17, 2009
    machine d422 giving sc 390 after making a few copies.the copies appear faint even with new toner.
5 Suggested Answers
hamzaskilltd
  • 316 Answers
SOURCE: Error Code SC402 in Ricoh Aficio 270
transfer roller negative current error
Posted on Jun 26, 2010
SOURCE: I Cannot solve SC541 Error in RICOH Aficio 270
It's not the PCU (photoCONDUCTOR unit), It's either a thermistor or blown out heater lamp in the fuser. Call a tech. The code can only be reset in service mode
Posted on Aug 12, 2010
SOURCE: i have a Ricoh aficio
hi i have a ricoh gx2500 printer i loaded new inks and now it wont print just saying ink levels low and red light on..
Posted on Mar 08, 2011
avelino
  • 35 Answers
SOURCE: I Have a Ricoh Aficio
try to re install the program of your printer or try to install your printer in other pc.. if it work in other pc try to repormat your pc and re install the the program of your printer..
Posted on May 09, 2011
Service code sc 390 RICO Aficio 1015 coppier
please refer to link below, it may or may not refer to a different machine but the meaning of the code should be the same
http://printcopy.info/?l=en&mod=free&chap=erc&brand=Ricoh&model=Aficio%20550&code=SC390
Jun 04, 2015 | Office Equipment & Supplies
Ricoh aficio 1035 copier, functioal problem SC390
The TD sensor could be bad. But more than likely you need to replace the dev material and the drum and charge roller
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Sc390
SC390 = Toner Density Sensor abormality
Possible causes:
  • Poor concentration of developer
  • Toner density sensor faulty
Are the prints/copies coming out ok? If the copies are very faint or heavily overtoned then changing the developer may cure the error code. If the copies look OK then you probably need to get the toner density sensor replaced by an engineer.
Hope this helps.
Feb 10, 2011 | Ricoh Aficio 450 Copier
I have a Ricoh aficio 2018D problem is SC390 Code i reples PCU Unit Lower unit/Drum & Developer but sc390 code problem not solw. Please help Me.
The TD sensor is reading an abnormal value, this could happen if no toner is getting into the developer unit or it could be a bad TD connection or TD failure. Would suggest checking to see if the toner supply path is working first.
Check that the toner bottle is empty and most of the toner in the development unit is depleted.Add a new bottle of toner, run a forced toner until it looks good, then run td initialization.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Ricoh Office Equipment & Supplies
Sc390
SC390: TD sensor error
- Possible causes -
· TD sensor abnormal
· Poor connection of the PCU
Dec 30, 2010 | Ricoh Aficio MP 1600L Black and White...
Jun 23, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
My Ricoh 2232c copier has displayed error SC374 can you tell me what this means?
SC322 Laser synchronization error SC324 LD drive current over SC390 TD sensor error 1 SC374 Development bias leak SC393 TD sensor error 2 SC401 Transfer roller leak error 1
Jan 14, 2010 | Ricoh Aficio 2232C Color Copier
Getting a code SC390 on my Ricoh Aficio 1045
I call my tech support. The problem does have to do with an abnormal reading of the Toner density sensor.
Adding toner may be just the ticket to fix the problem.
Apr 15, 2009 | Office Equipment & Supplies
259 people viewed this question
jasbo
jasbo
