Question about Kenmore 62602 Electric Dryer
How do I get the top off to replace the switch in the door assembly?
  • Kenmore Master
  • 8,220 Answers
Posted on Sep 13, 2010
What is an error code of DL?
F/dL error - Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
If all the connections are good replace the CCU.
Good luck.
Aug 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
How can I change the mirror control panel?
Firstly, get a replacement switch. Carefully take off the cover of the door handle (mine is the diagonal kind - 2002) and then unscrew the two screws at the top and bottom of the handle. Then Unscrew three screws at the very bottom of the door panel - they are the "star" kind - a tork screw. Carefully pull out the snaps on the sides of the door panel. They just pop out of holes in the door frame. Be carefull not to pull too fast or suddenly. Then pull straight up on the door panel. It can be very sticky at the top but gently work it out of the rubber slot at the top. OPTIONAL: Now that the panel is free, disconnect the electrical and door pull cables. Make a note of what connected where! You can skip this step if you can do the next step in a tight spot... You'll see the assembly for the door handle, lock, and mirror switch. There is a screw by the door handle. Unscrew that, then carefully pry open the clips that hold the assembly in. The whole assembly will come forward out of the door panel. Now, carefully unclip the mirror switch. It will come forward out of the assembly. Place the new switch back in its place, and re-clip. AT THIS STAGE, RE-CONNECT THE ELECTRICAL WIRE TO THE SWITCH AND TEST! Replace the assembly back in the door panel. Replace the screw by the door handle and re-connect the wires and cables. Then "Hook" the top of the door panel on the rubber slot. You can check the other door to make sure it's right. Carefully snap back in the sides of the door panel then reconnect the three screws at the bottom. Finally, replace the two screws in the door handle, and replace the door handle cover.
Best of luck
Jan 11, 2011 | 1999 Volkswagen Beetle
My machine wach but do not spin a the end.
Note: This solution is intended only for asker qualityisc as per Live Chat session discussion. Error code reads E47 which means the Control board thinks the PTC circuit (wax motor) is open.
Unplug the machine then remove the spring-loaded wire loop that holds in place the front of the bellows over the lip of the door opening in the front panel.
Using needle nose pliers, start where the spring and wire are connected at the bottom of the bellows and pull the wire out of the groove of the bellows then pull the bellows off of the lip of the front panel.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine and disconnect the electrical connections.
Measure the resistance of the wax motor. The normal resistance is around 1500 ohms. Shorted or open circuit wax motor means the door lock and switch assembly needs to be replaced.
Simply
replace the door lock and switch assembly (part #131763202) if the wax motor reads shorted or open to address the issue. But if the wax motor resistance is normal, check the continuity of the door lock and switch assembly wire harness, particularly the wax motor wire harness. Start with the continuity of the red/black wire of the wax motor harness to each of the red/black wires of the door lock and switch assembly harness. They should all have continuity; otherwise, replace the harness.
Remove the top panel to access the control board if further continuity test is necessary or if the red/black wire of the wax motor harness has continuity with the all other red/black wires of the door lock and switch assembly harness.
Remove the screws attaching the top panel to the rear of the cabinet then lift the panel off. The console can be removed from the cabinet to completely access the control board connections, particularly the door lock and switch assembly harness connections. Check the continuity of the red/black wires at the door lock and switch assembly to the red/black wire of the harness connected to connector J2 on the control board.
The problem is in the control board if the wax motor is good and the door lock and switch assembly wire harness has all the necessary continuity. The only viable solution, should that be the case, is the replacement of the control board.
Oct 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washer works but it will not work in the spin cycle
Every washing machine, top or front loader, has a safety feature that disables the spin functions and that is the lid switch/lock for top loaders and door switch/lock assembly for front loaders. This is to prevent injury when the lid/door is opened during a high speed spin. Check lid/door switch harness and connections. Replace lid/door switch assembly if no issue found with the harness and connections.
Sep 30, 2010 | Kenmore Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Will get hot but drum will not go around
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
If the door switch is in good condition and, it is functioning, replace the electronic control board assembly.
Apr 22, 2009 | Whirlpool GEW9200L Electric Dryer
B door open
There are two switches, so if you changed the one that was working....
Possible parts affected could be
- cover top
- cover fuser
- cover front assembly
- the switch
1) check the condition of the cover - top, front assembly and cover fuser closed?
2) on the cover top there is an "actuator", a plastic bit, which presses down on the switch assembly top - is that plastic bit broken, bent or deformed?
3) on the cover front assembly there is also an "actuator", check this
4) and of course same for the fuser cover
5) top cover, check the switch, disconnect the switch (P116-1) and press/release it - does that make a difference. If not replace switch
6) same procedure with the switch (P115-1) for front cover.
Feb 04, 2008 | Epson Aculaser C1100 Printer
Frigidaire Front Load Door Lock Broken and Noisy FWT449GF
Its looks like a lid switch issue. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Good luck!
Sep 08, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Replacing control valve/burner valve switch
This just started to happen to ours too. It's because you can't get let water get into the valve/switch assembly. Ours got so much water in there that it was making huge sparks and flames which charred up the switches. You may have to replace the whole 5-burner igniter switch assembly. I think it's part number 74010753. To access, remove 2 screws under the front of stovetop. open Top oven door to access. remove the 2 screws that hold the gas valve assembly. Remove 2 screws out of each burner assembly. Remove the green grounding wire on the right hand corner of stove top. The stove top will come off revealing the 5 white igniter switch assembly which is all wired together in parallel. Remove the large metal panel on the rear. There are two wires that are off the 5-burner switch assembly that you unplug. Replace this whole assembly and the problem should be fixed. Hope this helps
Jun 18, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore 62602 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
