Question about Electrolux EIED55H Dryer
I was drying and the dryer shut off and gave an error message of E64
  • Anonymous Mar 14, 2014
    dryer keeps shutting off displays E64
  • 4,323 Answers
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Posted on Sep 13, 2010
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 02, 2015 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LWO has a error "E64" listed on the window. What error is this in reference too?
E64 means Heater Open Circuit. Either your heater coil is blown or you have some bad wiring to the heater coil.
Dec 16, 2014 | Frigidaire Dryers
My Frigidaire Dryer (Model #FASE7073LW0) has an "E64" message listed. What error is this in reference too?
Good Morning Yasmin Abdullah, I am happy to assist you!
Based off the information you have provided your Frigidaire dryer is displaying error code "E64". "E63" typically stands for heater open circuit, which means that it could be a faulty wiring harness or heater. I would suggest performing a reset on your dryer by disconnecting power from it for ten minutes. This could be a false error code or a miscommunication within the board and a reset will help to clear that out. I hope this information is helpful to some degree. -Matt
E64 error code electrolux dryer
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
E64 - Heater thermostat
  • Thermostat faulty (replace heater unit)
  • Heater unit faulty
  • Wiring faulty
  • Electronic board faulty.
Dado
Aug 09, 2014 | Electrolux Dryers
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Dryers
I have an error code 64 on my dryer. I am out of work doing chemo right now. can anyone tell me what the problem is
If your Frigidaire Affinity dryer is beeping at you and giving you the "E64 CALL SERVICE" business, chances are you have a bad heating element. The good news is, with a screwdriver, a pair of pliers (a multimeter if you have one) and a new heater element you can fix this yourself and save a couple hundred bucks.
Below I outline a step by step process to do this on the Frigidaire Affinity, but this guide may help with other dryers, as they basically all function the same way.
A WORD OF CAUTION: You will be handling a lot of thin sheet metal components. Be careful as it is easy to cut yourself on them.
First you'll want to unplug the dryer. Then disconnect the vent hose and the water feed (if applicable). Be sure and shut off the water valve first, or you'll have a mess!
http://therandomfix.blogspot.com/2013/07/frigidaire-affinity-e64-error.html
Apr 03, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Error message e64
Hi
Sep 07, 2010 | Electrolux EIED55H Dryer
Electrolux EIED55H Dryer Logo
3,872 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
