Question about Microwave Ovens
Bread dogh container leaks. is there way to fit a washer to stop the leak?
  • 10,515 Answers
Unfortunately, there is nothing you could do to stop a leak. This is a common problem and the only option would be replacement. I wish i could have a better solution. There is no washer or seal or chemical that could fix this.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 13, 2010
Having a water leak in the left front of the machine at the bottom. Can't determine cause.
Either there is a leak in drum or one of the hoses and/or fittings under unit is leaking.
Gonna have to roll up your sleeves and check it out.
Mar 10, 2016 | Magic Chef MCSTCW16W2 Mcstcw16w2 Topload...
The fire output is very low and we can smell a small amount of lpg we have changed the gas regulator but it did not solve the problem
You must have either the wrong regulator, or low incoming pressure to the regulator and with the smell of gas I would suspect a leak in the system. Check all fittings on the lines with windex to see if you see it bubbling along any of the connections, if it is bubbling you have a leak. A better product to check for leaks is Snoop, but if you can't find it windex will work.
Jun 12, 2011 | Microwave Ovens
I need a hook dogh a701 kenwood mixer
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 14, 2011 | Microwave Ovens
I have a Franke faucet in my kitchen. (It has 3 levers - Hot, Pure and Cold). The faucet developed a slow leak. I tried to tighten the screws on all 3 levers and broke 1, so I have to replace it. To...
The cause of leaking is the ceramic gasket. Yes you can replaced it. Find your local hardware store then buy a repair kit for that faucet. If you can bring the sample bring it.
Please rate my help.
Thanks for using fixya.
Jan 10, 2011 | Microwave Ovens
My krups xp7200 is leaking water from the bottom. How can I open it to check the problem? thanks
You need to unscrew 4 screws in the front, three on the top (underneath the lid where you put the cleaning tablet), one inside the coffe container at the top, and pull gently, but firmly the little black nob inside the coffe container, that you use to adjust the coffee grinding, straight up. Then you can remove the coffee container on the top, and unscrew one screw underneath this container. Also, remove the two screws from the holes beneath the water container. NOW, you should be able to pull the front electronics off, and pull the main cover backwards, away from the front panel. You may have to bend it a little to get it completely off, but it is not a problem. Good luck! :)
Jun 15, 2010 | Microwave Ovens
My hand sprayer on my sink is leaking every time I turn the water on. It's leaking from the sprayer and in dripping under the sink. How can I fix this?
Check for a leaking O-ring/Washer/Seal and replace. Sometimes the internal parts of the sprayer head will wear out. Replacement sprayer heads can be obtained from your local hardware store.
I'll look forward to hearing back from you. :-)
Apr 26, 2010 | Microwave Ovens
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
