Question about Stairmaster 4400CL Stepper
Screen lights up momentarily but then shuts off. After many attempts to turn the unit on it may turn on or it may not. One thing is constant, the occasional flicker of the screen when operating (climbing) on the unit. Can you help diagnose the problem?
    Problem Solver:
  • 6 Answers
Sounds like low battery voltage. battery should provide at minimum 6 volts when tested "cold" without any activity on the unit
Posted on Oct 06, 2010
Wd65737 Mitsubishi 65 in dlp tv, Does not go past blue welcome screen
Can you call up the settings menu? Check to see if the ANT-1, DVD, and other ports are properly activated. You may need to re-scan for channels and to activate the HDMI ports for your other devices. Regards.
Aug 13, 2015 | Mitsubishi WD65737 65" DLP TV
Water heater pilot light is out, cant restart intelli vent controller
Possibly the air intake located at bottom of heater needs to be cleaned with feather duster under water heater.
Read your product manual for steps.
Copy following link for general illustration.
http://waterheatertimer.org/images/State-select-air-intake-400.jpg
http://waterheatertimer.org/pdf/Flame-Arrestor-Screen-Cleaning.pdf
Other causes can be bad intellivent gas control valve, poor venting, hot attic, low gas pressure, dirty combustion parts, tripped FV system.
Copy following link for available intellivent troubleshoot resources:
The service manuals are large files and open slowly.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Jul 26, 2012 | Water Heaters
I was watching a film then my ps3 suddenly shut of with the red light constantly flashing, so i went to turn it back on and and then the yellow light came on and it shut back down with the red light...
You have the infamous YLOD, aka. Yellow Light of Death. This is the number 1 cause of pS3's dying. It is an overheating issue linked to your CPU and GPU (the processor chips) You will need to find a local PS3 repair shop who can repair this. Do not try to attempt repairs seen on the internet yourself as some would suggest.You could make things much worse and render the unit totally unresponsive. The repair process takes about 3 hours.
IT CAN BE FIXED
IS THERE A DISC STUCK INSIDE?
If you have a unit that is not backwards compatible, any non 60g or 80g then you can retrieve your disc.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 24, 2011 | Sony Playstation 3 (PS3) Console
Green light turns on momentarily, then nothing from unit
make sure batteries are tight in unit ,making good connection there are many internal things that could be wrong no rotation could be bad drive motor broken belt bad pcb robotoolz now owned by bosch who owns cst-berger discontinued robotoolz lasers there is a guy who will give free estimate on repair A.P. Service & supplies 610-944 8030
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
We have a Tappan energy efficient stove. It is the worse appliance we have ever owned. It will not stay on. It turns on the then goes off constantly. Is this really how this thing works or is something...
deppending on your temp setting the burner are design to go on and off,however they should stay on unit the hit there temp range and then the will shut off momentarily and then back on when needed.times are the lower temp needed the mor cyclic rate they will have.
Mar 08, 2010 | Kitchen Ranges
Help fix screen t.v.
What red light are you referring to? If you are talking about the red l-e-d power light beneath the screen, that is the power off light. If that red light light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply.
Oct 22, 2008 | Proscan 19LA25Q 19 in. LCD Television
Tv turns self off when turned on
Does it blink a certain amount of blinks pause a second or just blink constantly with no pauses? Let me know it will blink a code if its going into protected shutdown. And it will blink constantly for another reason.
Jan 22, 2008 | Sony KP-53HS30 53" Rear Projection...
Won't Turn On....Immediately Switches To Standby
Did you get your tv fixed? It may be the Sub power supply unit. If the main supply went out it would not light the display at all. Yes it is time for th repair shop. Good Luck.
Jan 25, 2007 | Sylvania 6842-PEM 42 in. EDTV-Ready Plasma...
Stairmaster 4400CL Stepper Logo
170 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
