Question about Dell 962 Photo All-In-One InkJet Printer
Light flashing say ink low but brand new ink - Dell 962 Photo All-In-One InkJet Printer
  • 41 Answers
Try to remove the ink cartridge and re insert it again. Then cancel all the pending documents to be printed on the system tray of your desktop and restart pc. Hope this will help.
Posted on Sep 13, 2010
How to change ink cartridges on an Epson CX 3800
Be sure you have a new ink cartridge before you begin. Once you start replacing a cartridge you must complete all steps in one session.
1. Make sure the Epson CX printer is on.
2 Make sure the document cover is closed, then open the scanner
Caution: Do Not open the scanner when the document cover cover is open.
3. Press and release the " ink " button. The ink cartridge moves to the check position and the
" On " and " ink " lights flash. If one of the cartridges is low or empty, the printer moves the
cartridge to the _ink out mark.
Note: Don't hold down the " ink " button for 3 or more seconds or the printer starts cleaning the print head.
Caution: Do Not move the print head by hand; this may damage the printer, always press the ink
button to move it.
4. Press the " ink " button again
a. If more than one cartridge is low or empty, the next cartridge moves to the_ink out position.
b. If all of the empty or low cartridges have been identified, the print head moves to the ink
cartridge replacement position.
5. Open the cartridge cover.
6. Squeeze the tab at the back of the empty/low cartridge and lift it straight out.
7. Before you open the new ink cartridge package shake it four or five times, then remove it
from the package.
Caution: Do Not remove or tear the label on the cartridge; otherwise ink will leak.
Do Not touch the green chip on the front of the cartridge, this can damage the
ink cartridge.
8. Place the new ink cartridge into the cartridge holder and push it down until it snaps into
place.
a. Replace any other cartridges that need to be replaced.
9. Close the ink cartridge cover and press it until it clicks into place.
10.Close the scanner.
11. Press the " ink " button The print starts charging ink and the " On " light starts flashing. This
takes about one minute. When it's finished the " On " light stops flashing and remains on.
and the " ink " light goes out.
Caution: Never turn off the printer while the " On " light is flashing or you'll waste ink.
Note: If the " ink " light stays on ( not flashing ), the ink cartridge may not be installed correctly.
Press the " ink " button again and reinstall the ink cartridge until it clicks into place.
Feb 09, 2011 | Epson Office Equipment & Supplies
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
I have an epson stylus NX100 and i just put brand new black ink in it recently i printed two pages max i went back to use it and it says that my black ink has expanded and i have to buy a new one? what...
***hi there,ill be willing to help you on that. ****
try to reseat the cartridges first to charge it again, reseat means Remove and reInstall the Cartridges. after doing that and still the same issue, and you have an extra set, try to load another brand new ink,just to isolate if it is the ink thats causing the problem, if the same issue persist, its not the ink that you bought, its the printer already, the printer is broken, call epson if it is still covered by 1 yr warranty, 1 yr with in date of purchase. they will send you a replacement printer.
1. Turn on the Epson Stylus NX100 Series.
If a cartridge is expended, the ink light on the control panel stays on. You must replace the cartridge to be able to print.
If the ink light is flashing, a cartridge is low on ink; replacement is recommended.
2. Open the scanner and prop it up with its support
3. Press the nx100_tx100_ug.1.93.5.jpg Stop button. The print head moves to the nx100_tx100_ug.1.93.6.jpg position to indicate which cartridge is low or expended.
4. Press the nx100_tx100_ug.1.93.8.jpg Stop button again. If another cartridge is low or expended, it moves to the nx100_tx100_ug.1.93.9.jpg position. Press the nx100_tx100_ug.1.93.10.jpg Stop button again to see if more cartridges are expended. If no other cartridges are low or expended, the print head moves to the replacement position on the right. 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it.
7Remove the cartridge from the package
8. Remove the yellow tape from the bottom of the cartridge.
9. reInsert the new cartridge into the holder and push it down until it clicks into place. 10. Once you replace all the necessary cartridges, lift the scanner slightly, release its support, and lower the scanner.. 11. Press the nx100_tx100_ug.1.93.18.jpg Stop button to begin charging the ink. This takes about 1 1/2 minutes. When the nx100_tx100_ug.1.93.19.jpg On light stops flashing and remains on, ink charging is finished. Caution:
Never turn off the Epson Stylus NX100 Series while ink is charging or you’ll waste ink.
Jan 21, 2010 | Epson Stylus NX100 InkJet Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Put in new ink cartridge -- won't print
Try lifting up the cover. If the ink level is low in a print cartridge, the Print Cartridge Status light stops flashing. If the problem is not related
to low ink, the light continues to flash after the cover is opened. It might be that the new cartridge is defective. Check the connections and see if there isn't anything keeping it from making contact.
Jan 26, 2009 | HP DeskJet 920c InkJet Printer
Ink was low I put a new cartridge in still says low wont print.
Hi
try reinstalling the ink. if all fails call epson for replacement ink at 562 276 1300
Jan 02, 2009 | Epson Stylus 2200 InkJet Photo Printer
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Brand new Printer lights flashing
You should install driver first, then connect printer when prompted, then install inks, as it needs the driver to tell it there are full inks fitted, refer to the manual.
Dec 20, 2006 | Ricoh Aficio G7500 Printer
Dell 962 Photo All-In-One InkJet Printer Logo
29 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
