Question about GE Dryers
Ge dryer has heat and turns on but doesn't go around: Does not spin around.
  • 494 Answers
Your drum belt has probably broke. If it's not squealing or burning rubber, then it probably broke. Douglas
Posted on Sep 13, 2010
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
My dryer mod rex5634kq1 stopped working
what stopped? Does it not Spin? if so it could need a new motor. If it spins but doesn't heat up. it could just be a heat sensor in the back that needs to be replaced or a heating element. if nothing happens at all it could be the start button needs to be replaced. Turn the dryer around and open up the top back panel. should be about 6 screws. inside there will be a diagram on the schematics of the dryer.
Hope this helps.
Mar 27, 2012 | Roper REX5635E Dryer
Dryer doesn't heat
Is it electric or gas? Most likely u have a blown thermostat or fuse. Could also be a bad heating element if electric. Or bad solenoid coils if gas
Nov 15, 2011 | GE Spacemaker Washer and Dryer Electric...
Dryer turns on and lights , heats approx. 1 min. goes out when up to temp, stays off approx 1min. lights again, may do this for 5 times then just doesn't relight. Stays cold, keeps spinning drum. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 19, 2011 | GE DCVH515GF Gas Dryer
My ge dryer DBXR453EVOWW , drum doesn't spin, does heat
heatman101
Jun 12, 2011 | GE Dryers
GE spacesaver stack washer & dryer: The
the dryer won't heat up. everything else works. the drum goes around with clothes in it. it just won't heat up .
Jan 03, 2010 | GE Spacemaker Washer and Dryer Electric...
GE Dryer has not heat
dryer spins fine but wont heat
Aug 05, 2009 | GE Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
New Dryer Belt
The switch on motor is sticking or broke. You can try cleaning lint from motor and around switch. (Box with wires going to it on motor.) If this doesn't work you probably need a motor.l
Nov 07, 2007 | Amana ALG331RAW Gas Dryer
Dryers Logo
32 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
