Question about Sony FD Trinitron WEGA KV-27FS200 27" TV
I accidently knocked my satallite box down, which pulled out and broke off the VHF/UHF jack. Is this something that would be expensive to fix, or is it something I can fix myself?
  • proanemk Sep 13, 2010
    Addentum: Just to clarify my post, I broke the VHF/UHF ******** from the TV; it actually pulled completely out.
    Pat
  • Sony Master
  • 1,213 Answers
The repair to replace the RF connector can be a long and complicated one. You should probably take this to a TV tech for repair. Or in another case, if you have a video one or a video two connection, apply RCA cords from the satellite box to the TV. Save a the price of a repair. Thanks for asking and give me a few hands!
Posted on Sep 13, 2010
Which is better, vhf or uhf
In many business settings you can use either VHF or UHF with success.
VHF: Especially good for people who work somewhat line-of-sight or outdoors. VHF gets around rocks, dirt, hills and trees well and can also be used in many indoor situations.
UHF: While VHF and UHF will both operate line-of-sight up to 2 miles, UHF (450mAH range) gets in and around metal better and even has a better metal punching capability. It also works well in and around concrete structures.
May 01, 2014 | Motorola Radius Vhf Sp21 2 Way Radio...
I am not good with electronics. Have bought a jensen antenna for a tv - tv611 - how does the UHF n VHF wires both fix into the 300/75-ohm balun????
Go to walmart but UHF/VHF connector,one that you can connect both wires too and then plugs into TV.Cable IF
Aug 21, 2010 | Televison & Video
I DON'T KNOW HOW TO CHANGE MY TV TO CABLE OPTION RATHER THAN UHF OR VHF
Well let me ask some questions!
1) UHF and VHF are types of off air antenna source signals.
2) Cable TV has both the Analog 'UHF and VHF' signals on them along with the new Digital TV signal sources.
A) Is you TV have a Digital Tuner built into it or are you using a CABLE TV box to hook up to your TV?
Blessings always,
A/V Media Tech Guy
Nov 29, 2009 | Televison & Video
Vhf/uhf jack broken
You can try to attempt to solder it back on, but the metal is thick and hard to get it to stick with a solder iron..
Most likely you should get a new tuner, which depending on your expertise, may require a pro.
You can take your model number to www.partstore.com and search for your tuner and order it.
Otherwise look to spend between 200 to 275 bucks for a pro to do it.
Jul 09, 2009 | Televison & Video
Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a 1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The 1/8" plug on the adapter goes in the external antenna jack on the TV, and the other end connects to the coaxial cable that goes to the TV (RF out) jack on the converter box.
Jun 08, 2009 | Casio TV-980 2.3 in. Handheld Television
Conversion boxes-Do I need one with an outside atenna?
you will need a converter box if you do not have a digital ready television. If you have a digital television, then no you do not need one. make sure of the type antenna you have, as there are uhf only and vhf only and combined uhf/vhf. if you only have a uhf only antenna you may be missing out on channels.
Jan 23, 2009 | Televison & Video
Best picture and sound
connect coaxial cable connector from your cable service company to cable box-----in jack.
2-using coaxial cable connect cable box out to tv-vhf/uhf jack.
connect projection tv audio out (var-fix)jacks to avr 230 line in.
Aug 22, 2008 | Audio Players & Recorders
Sanyo ds 31350 tv
Hi there!
Assuming that you tried to tune stations onto the UHF bandwidth and received nothing,Commonly the tuner box is probably at fault and needs replacement. The VHF and UHF signals are split inside the tuner so if you receive VHF fine then UHF should as well unless faulty of course. Some circuits require an external IC to do the switching, but more on the older models. Regards and good luck, JUS004
Apr 02, 2008 | Televison & Video
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA KV-27FS200 27" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
