Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirlpool cabrio WTW6600SB0 spin to fast and start to hit the sides for the metal cover, so she stop and tell me to balance the cloths but this it don't work. Because start spin again fast .What can I do?
  • 4 more comments
  • diesan12 Sep 13, 2010
    I don't have the manual can u please tell me where is exactly the balance ring?
  • diesan12 Sep 25, 2010
    I have to empty the balance ring, because has water inside how I do to empty the top one balance ring, I tried to find a screw on the top or some hole but I can't finded can u
    Please help me to empty the balance ring
    How I do too empty the water in the balance ring on the top because don't have screw or holes
  • diesan12 Sep 27, 2010
    The unbalance when the washer spin still there what can I do more to fixit
    Already check the suspension rods they are in a good place not reflect damage anyone plus I put new grass in the bottom of the plastic, what more can I do. Buy a new washer? And what make of washer is good because whirlpool comes whit a lot of problems....
    What about the washers front load they are better than the top load? And which is more better
    President:
  • 1,554 Answers
Water may have entered the balance ring, the one sitting on top of the basket, and as as soon as the machine starts spinning, the basket becomes unbalanced. The machine/motor control will try to balance then stop and flash the unbalance load fault code if it fails to correct it. Check the balance ring for any water content and empty it.
Posted on Sep 13, 2010
  • 2 more comments
  • Jahn27
    Jahn27 Sep 13, 2010
    Here's the basket with the balance rings:
  • Jahn27
    Jahn27 Sep 27, 2010
    Check the four suspension rods suspending the tub from the top of the cabinet. Make sure they are attached to the top of the cabinet and bottom of the outer tub and the counterweight is still in place at the front bottom of the tub. Visually check them for any sign a wear or damage.
  • Jahn27
    Jahn27 Sep 27, 2010
    I suggest you call a qualified repairman to look into the problem. But if you opt to replace the machine, I still recommend Whirlpool, Kenmore, or Maytag top loaders using transmission assembly, not the electronic controlled top loaders using direct-drive brushless DC motors. The components easily go bad and expensive to replace. There are lot of problems reported with these electronic brushless motor washers unlike the other type which are reliable, easy to troubleshoot and repair.
  • Jahn27
    Jahn27 Sep 27, 2010
    The front loaders are better than the top loaders in terms of efficiency (energy and water) but when it comes to durability. nothing beats the top loaders.
Our whirlpool cabrio washer model wtw8500dc0 will start a cycle. It shows error codes E9 F7 what is the problem?
you either have a bad motor or a piece of clothing is stuck between the tubs,open the lid and see if the tub will spin,if not clothes got down between the tubs.also check the wires down near the motor,sometimes the snap inside the casing from the tub going off balance,if there is a piece of clothing stuck between the tubs you pop off the top plastic part on the tub but first you have to get the top of washer off to do this,usually the clothing will be in the back right side,the metal might be sharp on the tub,i use a coat hanger to hook the clothing and pull it out,good luck and hope this helps,go here to see error codes.
http://www.searspartsdirect.com/washer-repair/error-codes/whirlpool-2015-cabrio-top-load-washer-error-codes.html
Sep 26, 2017 | Whirlpool Washing Machines
How do you remove the cover for Cabrio Platinum Top Load Washer to see if clothes have gotten stuck between wall & basket of washer. I can not wash one load without getting the UL Off Balance Code!
it is extremely unlikely that clothes have got to the position you mentioned
unbalance comes from
1--- clothes out of balance in the tub--too much on one side
2--machine not level on the floor --- rubber feet missing from adjuster bolts
3-- suspension rods and insulators for the tub broken or missing
these suspension rubbers/ plastics break on a regular basis and allow the tub to sit at an unlevel state causing an unbalance situation when spinning
top covers are either held in place with screws at the front and back ( under plastic trim buttons ) or simply clip on to the side walls at the top
talk with a service agent as to how to remove the top or download a workshop manual for the machine from the net
Oct 29, 2016 | Whirlpool WTW6400SW Cabrio Washer
UL comes on in spin cycle. I cannot spin water out of clothes
the code is telling you that your load is out of balance, move clothes around and try again or you may have the start of bearings going bad
Aug 19, 2015 | Whirlpool WTW6400SW Cabrio Washer
My Whirlpool Cabrio washer model WTW5610XW0 type 588-02 spins then stops and clothes still come out wet.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
Dec 12, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Tub is off balance
The tub is out of balance. When it starts hitting the sides, stop the washer and move your clothes around inside the tub to balance the tub. Now start it to spin again. This should stop the tub from hitting the sides.
Feb 14, 2012 | GE Washing Machines
Why does my washer gets off balance during the spin cycle and how to repair it
A QUICK FIX IS TO OPEN THE DOOR TO STOP WASHER, THEN RE-DISTRIBUTE THE LOAD SO IT BALANCES OUT IN THE SPIN CYCLE. OR, REMOVE SOME OF THE CLOTHES, IT COULD HAVE TO MANY IN IT.
Feb 21, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
595 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
