Question about Epson Stylus Photo R320 InkJet Printer
Epson Stylus R320
My printer seems to work at times but for most time not.  I know its not my printer all works. i try to print onto a cd and it worked the other day when I changed a few things on my HD but i just need to know wht the problem is could someone pls help. Is there something on my mac G4 that I need to change ?
Thns  Jewels
    Genius:
  • 2,035 Answers
Reinstall the printer drivers on your computer and then try to print.
Posted on May 15, 2008
I have an Epson Stylus PHOTO R320, prints fine except when I try to print on a CD. I have windows 7 64 bit. I downloaded all the drivers for that and as I said it prints fine except when I want to p
My research shows that you must use special printable CD/DVD media which generally costs a bit more than nonprintable media. Possibly that is the reason. You don't give much info on what happens - if it feeds and the result is blurry I would think it is the media.
Jan 04, 2015 | Epson Stylus R320 Digital Photo Inkjet...
Epson Stylus Photo R320 InkJet Printer not printing black or yellow
I had same problem, fixed mine like this... just choose the head cleaning option and run this about 5-10 times in a row takes about half hour or twenty minutes but it starts printing black eventually.
Dec 27, 2010 | Epson Stylus Photo R320 InkJet Printer
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson R320 Paper Feed Problem
Biggest POS in the world. Brand new and doesn't work right. Will never buy from this company again!
Oct 02, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R200 and R320 Status monitor in Vista
I was able to install the original XP status monitor from the CD, onto Windows Vista Home Premium.
On the install cd, you need to open the 'STM3' folder under whatever language you are installing, 'English' in my case. There are several .exe files in that folder:
E_S1LAC2.EXE
E_SCHK02.EXE
E_SIINS2.EXE
E_SPSU02.EXE
STMSETUP.EXE
For each of these, right click on the file, and choose 'Properties'. Under the 'Compaitbility' tab, choose 'Run this program in compatibility mode for:' - Windows XP (Service Pack 2).
Then run the 'STMSETUP.EXE' file, and it should install properly, and work. Although I cannot guarantee that it will work on your system, or that it will not have any negative effects on your computer.
So far, I have not had any trouble with it.
Aug 03, 2008 | Epson Stylus Photo R200 InkJet Printer
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
63 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
