Whirlpool topload washer....there is a small inlet filter where the cold water enters the machine. I accidentally broke it and now I cannot get the cold water to stop running. Does this filter have to be inserted in order to make the cold water stop when I press in the button??
  • 417 Answers
you have debris caught in your valve which wont let the valve close. the back of the machine has to come off and you have to remove the whole valve assembly and clean it out. they are servicable. its slightly complicated but if you were able to get that screen out you could probably do it. first unplug it. the assembly the hoses go into(red plastic?) inner part has to be taken out and has to come apart. have a digi cam handy and take pictures. begin removing the bolts on the back of your machine. then once the back is loose GENTLY remove the outlet hose and the wiring harnesses and the bolts that hold it to the back of the machine. now that you have it out study it. it comes apart and has to be put back ((exactly the way you took it apart)0 so be ready with the camera and left brain. remove the additional screws and you will see the springs and the magnet assemblies, the valves and the debris. clean all that out , use your finger to check plunger operation. replace in reverse order good luck..
jm
Posted on Sep 13, 2010
My Whirlpool Duet Washer #GHW900LW1 does not pull the hot water.
Sorry this answer is about 1 month late, but in case you're still having the issue, it is likely due to 1 of 2 possibilities (or combination of both).
Most likely, the small inlet screen, located on the back, (where the hot water hose enters the machine) is clogged. This is a common problem that restricts the flow of hot water into the machine.
To check or clean this, just unscrew the hot water hose where it enters the washer. It sits just inside that fitting.
The other possibility is a bad or clogged inlet valve. The inlet valve controls the flow of hot and cold water into the machine. It is opened and closed via an electric solenoid (part of the intake valve unit).
The inlet valve is the same unit that houses the screen I previously mentioned, and is just inside the back panel of the washer, where the two inlet hoses thread onto.
Oct 06, 2014 | Whirlpool duet Washing Machines
Tip
LG Washing machine IE error code Solutions
An IE error code will appear if the washer has not filled with water in approximately 8 minutes.
Are the water valves opened completely?
If an IE error code appears on the washer, check to make sure both hot and cold-water taps are open completely. After both valves have been opened, unplug the washer for 10 seconds and retry the wash cycle.
Are the inlet hose filters clogged?
There are filters on the inlet hose connections of the washing machine. They are intended to filter away mineral deposits from hard water and other debris from getting into the unit. If clogged, water will not flow through these filters into the washer. Turn off both the hot and cold water taps, disconnect the inlet hoses from the back of the washing machine, and clean the inlet filters gently but thoroughly.
Are the inlet hoses attached properly?
If the inlet hoses are not attached to the machine correctly, it will prevent proper water flow to the washer. Turn off the hot and cold water supply then disconnect and reconnect the inlet hoses. Ensure that they are threaded properly. After the hoses have been reconnected, open the water taps completely, check for leaks, and unplug the washer for 10 seconds and retry the wash cycle.
NOTE: The inlet filters are inside the hose connections on the back of the washer. Because of their small size, take care when removing and cleaning the inlet filters so that they do not break.
on Jun 02, 2011 | Washing Machines
I have a Whirlpool Ultimate Care II; when I choose cold water, it takes at least 2 hours to fill the tub. Warm water will fill but the cold water comes out in two very small streams. Any help would be...
You likely have either a folded cold inlet hose (squashed) or self plumbing tap that is rusted in the cutter so slow filling or a blocked mesh filter in the cold hose connection on the back of the machine, try all three and you should have the answer.
Sep 05, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Very slow cold water fill, why?
First make sure that you have adequate water flow from the hose bib coming from the wall. You can do this by turning off your cold water connection at the wall, then disconnect the cold water hose. Then turn the faucet on and make sure the water flows freely. The most common reason for your problem is a clogged screen where the cold water hose connects to the back of the washer. To check this, disconnect the cold hose from the back of the washer and clean the small screen inside the cold water inlet on the washer.
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not fill when you select cold water
Q - My washer will not fill with cold water
A - More often than not, this is a bad fill valve. Please see the filling section.
There's no cold water Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
May 03, 2009 | Washing Machines
Soap residue
if you just have a soapy residue( bubles atop the clthing?? either your using way to much soap, or way to much of wrong soap.you need to use HE detergent specifically formulated for front loading amchins(low sudsing. or your having a cold water inlet problem set te hunit to cold/cold/ try running see if inded the machine fills
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool washer cold water takes forever to fill
your cold side on water valve may need the screen cleaned.if that doesnt help then you will need to replace your water valve.take hose off cold water side of water valve and you will see the screen.it may have alot of blockage.
Jan 04, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
Not able to do hot washing
My LG Toploader (wft753a) has a cold and a hot inlet, and the mechanism inside the machine simply turns the flow from each tap on and off. There is no internal heating element in it.
Nov 22, 2007 | LG WFT1071TP Top Load Washer
Whirlpool washer pump inlet filter
No, there is no filter before the pump inlet.
Sep 07, 2007 | Washing Machines
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
