Question about Health & Beauty
The power seat lift stopped working, although it does make noise. I've looked through the owner manual to see if it uses hydraulic fluid and I can't find any details. Any help would be appreciated. DD
  • alban62 Sep 21, 2010
    Hi Tim, Sorry about the lack of detail and the lapse in time, I haven't been able to access my laptop. It is a Rascal 600t.mobility scooter. I've replaced the batteries and it runs well. Before that, I was trying to charge it while the seat lift button was depressed. I'm not sure whether this may have caused any problems. Thanks. Dennis
    President:
  • 2,777 Answers
I need a bit more detail here, what make and model of scooter / chair are you using? Let me know and I can definitely help.
Thanks
Tim
Posted on Sep 13, 2010
Brake pedal hard with engine running, same as engine off
Check fluid levels in your power steering/brake reservoirs and look for hydraulic fluid leaks in the power steering and brake lines. Could be a bad power steering pump too. Your owners manual should show positions of hydraulic reservoirs.
Jun 15, 2015 | 2004 Cadillac CTS Sedan
What oil should i put in Fiat 411r hydraulics?
I read someplace the hydraulics use the engine oil. I have the same question. It looks like the hydraulic pump is located at the right hand side of the engine block, forward and is connected to it. Although the previous owner of my tractor used hydraulic fluid.
Apr 10, 2012 | Cars & Trucks
My Sears 3 ton high lift floor jack will raise but it won't lift any weight. The jack is only 3-4 years old and it has not had much use. I can't find my owners manual, and I want to know what I...
Sounds like it needs some hydraulic fluid added.Look for a rubber plug or screw on the side of the hydroelectric cylinder where the ram comes out.Buy a zoom spout oilier and save the oil.Use some solvent and clean it out.Add some hydraulic fluid and fill until it starts to come out.You may be able to find an oil can that will work for you. Leave the jack in the closed position when you fill it.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
May 19, 2011 | Garden
To remove 1993 mustang conv. top cylinders should top be up or down? thanks, bill
don't have 93. here's 94
Motor Assembly, Convertible Top Removal and Installation
NOTE: The folding top hydraulic cylinder rods should be in the fully retracted position.
Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove motor and pump assembly as outlined.
  1. Loosen each folding top motor upper and lower hose fitting on the sides of the folding top hydraulic lift motor and plate kit (533A00) .
  1. Remove the folding top hydraulic lift motor and plate kit .
  1. Remove each of the service folding top hydraulic lift motor and plate kit plugs one at a time and attach the tee fitting to the replacement folding top hydraulic lift motor and plate kit . NOTE: Make sure that the o-ring is installed in the bottom of each folding top hydraulic lift motor and plate kit port before attaching the hose tee fitting.
  1. Connect the folding top hydraulic lift motor and plate kit unit to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the folding top motor upper and lower hoses (53390) . Some noise squeal may be noticed due to the air. srb~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not overfill or the reservoir seal could be blown out.
  1. Carefully remove the rubber fill plug from the back and the reservoir and check the fluid level. The level should be at the bottom of the filler hole. If necessary, add Synthetic Mercon® Multi-Purpose Automatic transmission fluid E6AZ-19582-B (ESR-M2C163-A2) or equivalent.
  1. Replace the fill plug with a new fill plug.
  1. To install, reverse Removal procedure.
Section 01-17: Convertible 1994 Mustang. Workshop Manual
REMOVAL AND INSTALLATION Lift Cylinder, Power Top Removal and Installation
NOTE: The cylinder rods should be in the fully-retracted position.
  1. Remove pump and motor as outlined.
  1. Remove the upper and lower hose fitting from the folding top hydraulic cylinder (50600) . Use absorbent rags or a container to catch any hydraulic fluid that leaks out when removing the fittings.
  1. Remove each of the service cylinder plugs one at a time and attach the hose fittings. NOTE: Be sure each fitting is installed in the correct position on the folding top hydraulic cylinder .
    NOTE: Make sure that the tetra seal is installed in the bottom of each of the folding top hydraulic cylinder ports before attaching the upper and lower hose fittings.
  1. Connect the folding top hydraulic lift motor and plate kit (533A00) to a 12-volt power source and cycle the folding top hydraulic lift motor and plate kit in and out several times to purge the air from the hoses. Some noise squeal may be noticed due to the air.
Jan 21, 2011 | Ford Mustang Cars & Trucks
Top goes down but not up
the hydraulic pump /resevior is located behind the back seat.lift up front of bottom cusion,pull forward,remove.lift up on seat back,like it's hanging on hooks.remove.locate fill screw or rubber plug on top of resevior.w/ top down fluid should be 1/2'' to3/4''below top of fill hole.it uses automatc trans fluid,so if you see red fluid under the seat you have a leak.
Sep 23, 2009 | 1998 Chrysler Sebring
Ford 770A loader hydraulics lift cylinder shaft won't move.
Hello there:
when you dissconnected the hoses did you turn the cylinder upside down and let it drain cause some hydraulic lift assybelies have a small chamber in the head of them that retain fluid and with out removing the fluid it will do a hydraulic lock and wont be able to move untill you losen the bleeder screw if it has one ok please let me know how this goes for you
Sep 10, 2009 | Garden
19886 saab 900 convertible roof not working.
Hi David:
First, check the fuses for the hydraulic motor; if they're blown, replace and monitor (why did they blow? Perhaps an overload, or ...) These fuses are located in the engine bay on top of the fender by the front right wheel housing.
Next check the voltage supply to the top switch, possibly a loose connection or broken wire.
Also check relays C (raising top) and D (lowering top) under the rear seat.
Lastly check for voltage at the pump, also under the rear seat, when the switch is actuated, and that the voltage polarity reverses when the switch is actuated the other way (up or down).
After that, it's a hydraulic/mechanical problem. Check the fluid level in the pump reservoir (use SAAB fluid to top up if low) Fluid level should be at the upper marker with top down, and at the lower marker with top up.
Check behind the rear seat side panels that the piston shaft is still properly attached to the roof mechanism bracket at one end, and the piston itself is still firmly attached to the body. Look for any leakage from the system.
If all tests out OK and looks good under the rear seat and behind the side panels, then there is the possibility that the piston seals have failed and the fluid is just circulating around without activating the piston. Pistons are available (http://www.convertibletopguys.com/cgi-local/displaycat.cgi?cat=584 - scroll down) but the entire system should be removed to avoid getting hydraulic fluid on the interior.
However, that fact that you can operate the hood using the bypass valve (manually) would indicate that the hydraulics are likely OK, and that it's probably an electrical or mechanical problem.
Saabreur
Jun 09, 2009 | 1998 Saab 900
2000 BMW Z3 convertible top stopped moving with motor
There are a number of switches that need to be closed in order for the motor to operate. In particular there's a microswitch in the hood just above the left-hand seat which makes sure the motor doesn't operate until the hood has been lifted slightly.
My hood stopped working and I found the cable to the microswitch had been cut by the hood mechanism. Replacing the cable solved the problem.
May 13, 2009 | 2000 BMW Z3
Convertible top
here's some info
Symptom Chart Condition Possible Source Action
  • Folding Top Does Not Raise and/or Lower
  • Blown fuse(s).
  • Circuitry open/shorted.
  • Damaged folding top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Parking brake not engaged.
  • Go to Pinpoint Test A.
  • Top Hesitates and/or Comes Up Uneven
  • Damaged folding top motor upper and lower hose .
  • Damaged folding top hydraulic cylinder .
  • Damaged folding top linkage.
  • Go to Pinpoint Test B.
  • Top Does Not Raise or Does Not Go All the Way Up
  • Go to Pinpoint Test C.
  • Hydraulic System
  • Damaged fluid reservoir.
  • Go to Pinpoint Test D.
Jan 04, 2009 | 1989 Ford Mustang
Health & Beauty Logo
24 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
