Question about Kyocera FS-1118MFP Laser Printer
Kyocera km-1820 error occured call service person c6000
  • Kyocera Master
  • 525 Answers
Contents: Broken fusing heater wire
• In fusing warm-up, the time to reach
50 °C/122 °F exceeds 13.5 s, the
time to reach 100 °C/212 °F exceeds
10 s, the time to reach the primary
stabilization exceeds 10 s or the time
to reach the secondary stabilization
exceeds 24 s.
Causes: Poor contact in
the thermistor
connector terminals.
Thermistor installed
incorrectly.
Thermal cutout
triggered.
Heater lamp installed
incorrectly.
Broken heater
lamp wire.
Check procedures/corrective measures: Check the connection of connector YC4 on
the power supply PWB and the continuity
across the connector terminals. Repair or
replace if necessary.
Check and reinstall if necessary.
Check for continuity. If none, replace the
thermal cutout.
heater lamp
Posted on Mar 06, 2011
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
www.youtube.com/watch?v=Ef0WwaTXgtQ
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
pritner.blogspot.com/2013/08/solving-error-c6000-on-kyocera-mita.html
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
Se produjo un error llamar al tecnico C7980
On the screen of my KM 1820 copier Kyosera get the message "An error occurred calling a technician" and C 7980
how I can fix this error?
Sep 03, 2010 | Kyocera Copystar CS-1820 Black and White...
I am geting an error code of c3100 call for service on my Kyocera km1820. What does this mean???
Your scanner cable broken or twisted inside. You need to call local representative for further action.
Jul 12, 2010 | Kyocera Copystar CS-1820 Black and White...
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
I am getting an error C6000 on my Kyocera KM-1820 after we had a power outage. I can't seem to get it to turn off. What do I need to do in order to get the copier to work again and for it not to have the...
Go into the service mode ( 10871087 ) then enter 163 then hit the start button. This clears the C6000 (heater error) and if it is a false code due to a power outage, it will clear the code and resume normal operation. If the code comes back, you likely have a bad heater lamp or thermal fuse or thermistor.
Aug 19, 2009 | Kyocera Copystar CS-1820 Black and White...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
Have error: C6000 on Kyocera KM-3050
Have Kyocera FS-1118MFPF that is coming up with Error C6000. Can we fix this ourselves
Aug 02, 2008 | Office Equipment & Supplies
Kyocera FS-1118MFP Laser Printer Logo
1,371 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
