Question about Philips Televison & Video
Hello, we havea problem with my tv modal#42PFL3603D/F7 WE HAD APOWER SURGE THREW THE PHONE LINES IT SMOKED A DIODE AND AND POSIBLE AFUSE TO. iS THERE APARTS LIST I CAN LOOK TO SEE WHAT PART I NEED A DIAGRAM i COULD LOOK AT AND ORDER PARTS TO REPLACE THANKS FOR YOUR TIME, FRED
  • Philips Master
  • 1,212 Answers
Get on the website and find "Union Electronics.com". They may have what you are looking for. This site will ask you for a brand name and model#. I would recommend you replace the board you need! Give me a few hands and thanks for asking!
Posted on Sep 13, 2010
How do i replace part number 932224306671 on a philips 42pfl3603d/f7
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 30, 2014 | Philips Televison & Video
Turned on my Philips 42pfl3603d/f7 and you can see the images but everything is blue what part went bad and can I replace it my self
It sounds that the fault should be with its main digital board. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts. Try and determine whether you can repair it by yourself.
Nov 29, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Blue screen on Philips 42pfl3603d/f7
same result with all inputs? check all your input cables & connections
I have a 42PFL3603D/F7, and the tv doesnt turn on right away, it takes about 8 times for it to stay on. Any suggestions
Power supply is in need of repair. Pull out the power supply. You will find transformer (has blue tape). The location of this transformer is T701. Underside of this transformer, pin # EL41 is in need of a resolder.With a small screwdriver, scratch an area next and around this pin. With a hot soldering iron and solder...resolder this pin. Your TV will be fine. There are no capacitors to replace. This is one of the best power supplies built for Philips TVs. Thanks for asking, Matt of Martins TV.
Feb 18, 2013 | Philips 42PFL3603D/27 42 in. LCD TV
Model 42pfl3603d/f7 tv stopped receiving signal from remote.. remote IS working.. side controls on tv work it just does not process the signal from the remote.. unplugging does not help.. any ideas?
If you find the remote sensor eye located on the front of the TV, you are there!!! There is a small sensor board and a TV tech will have to replace this for you. There is usually a capacitor, resistor or diode that will need replaced. I replaced the remote sensor board. Thanks for asking and show a few hands of support.
Jan 11, 2011 | Philips Televison & Video
We had apower surge while watching tv. now there is no picture, but we can hear the program.
This could be the tuner damaged or a regulator damaged depending where the surge entered the set. Lighting will damage tuners while line power surges will damage regulaters and often horizontal output transistors along with sweep mode power supplies. Since you have audio I would suspect the horizontal output transistor first and check it from collector to base and emmiter for short with a digital volt ohm diode check meter. Check with diode check mode.
Oct 14, 2009 | Akai PT5598HD 55" Rear Projection...
Need help with TV calibration for philips
Try these, Contrast: 53 Brightness: 56 Color: 45 Tint: 2 Sharpness: 2
Color temperature: Off
Dynamic contrast: Off
Digital Natural Motion: Off
DNR: Off
Color enhancement: Off
Active control: Off
Feb 14, 2009 | Philips 42PFL3603D 42 in. LCD TV
42PFL3603D/F7 PHILIPS HDTV
Your problem is a combination of calibration of your TV and signal strength of your Dish system. Proper color calibration will remove the motion blur and SD issues in the average home. If you continue to have poor quality on your dish system after calibration, then Dish needs to check your signal strengths again. (AND fix it.)
Nov 28, 2008 | Philips 42PFL3603D 42 in. LCD TV
Televison & Video Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
