Question about HP LaserJet 4050 Printer
I need help Please my printer won't print gettig an error
Hi I am getting a message on my printer 82.0180 EIO 2 Error What can do I need to do to fix this problem. My daughter has a paper to print for school due tomorrow. Please help
    Problem Solver:
  • 13 Answers
The error message is related to the card that connects the printer to the network. The card is most likely bad. You may be able to clear the message by turning the machine off for 20-30 min, however this does not always work. If the error persists, you should turn off the machine, remove the card (it is in the back where the cables plug in, it has a connector similar to a large phone cord and can be removed by loosening the two thumb screws and sliding it straight back) and hook the printer directly to the PC with a parallel cable. You can also order a new card (Part#J3113A) online, but it will take some time and needs to be configured after installation.
Hope it helps,good luck to your daughter with her paper!.
Posted on May 15, 2008
Laserjet 2605 49 error
Error 49 is a firmware error. Try following these steps:
1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. You can try reprinting the job to see if it was a temporary error. 3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certainprint job, try upgrading the printer driver and / or firmware.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. Turn the printer off and delete the print queue. Then reboot printer AND computer, reconnect cables, and try printing again. 6. Remove all EIO devices from the printer (JetDirect cards, hard drives, etc.). If 49 error goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing. 7. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error. 8. Remember to reconnect all cables that connect the printer to the network or computer. 9. If the error persists, replace the firmware DIMM. 10. If error persists, replace the formatter.
Mar 10, 2014 | HP LaserJet 2605dn Printer
49 error
49 error means firmware error..
solution:
3. If error persists, try printing a job from a different software application. If the alternate job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or certain print job, try upgrading the printer driver and / or firmware.)
5. Remove all EIO devices from the printer (Jet Direct cards, hard drives, etc.). If 49 errors goes away, turn printer off, re-install EIO devices one at a time, and reboot printer each time to determine which EIO device is failing.
6. If printing still fails with all EIO devices removed, remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM-- printer won't function without this installed.) Turn the printer on with DIMMS missing. If the error no longer exists, install each DIMM one at a time, turn printer on, test printer. Replace a DIMM if you determine that it causes the error.
7. Remember to reconnect all cables that connect the printer to the network or computer.
8. If the error persists, replace the firmware DIMM.
9. If error persists, replace the formatter.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Dec 11, 2012 | HP LaserJet 3055 All-In-One Printer
Error 49.4c18 laserjet3800dn
49.XXXXX ERROR A critical firmware error has occurred.
1. Turn the printer off and then on.
2. Try printing a job from a different program. If the job prints, try printing a different file from the original program. If the message appears only with a certain program or print job, contact the software vendor for assistance.
3. If the message persists with different programs and print jobs, disconnect all of the printer cables that connect to the network or the computer.
4. Turn the printer off.
5. Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
6. Remove the printer EIO card.
7. Turn the printer on.
8. If the error does not persist, install each DIMM and EIO device one at a time. Turn the printer off and then on again after installing each device.
9. Replace DIMMs and EIO devices as necessary.
10. Reconnect all of the printer cables.
11. If the error persists, replace the firmware DIMM.
12. Replace the formatter and calibrate the printer.
Jul 20, 2011 | HP LaserJet 3800 Printer
My HP 4100tn will not print and I am getting error message as follows: 82.0180 EIO 2 ERROR I printed a document and then when I tried to print another document I got the error message. How can I fix...
Thank you for contacting FixYa with your printer inquiry.
This is an error caused by the jet direct card in your printer, try one of two things.
  1. Move the Jet Direct card from port 1 to port 2 on the printer.
  2. Replace your jet direct card with one that you know is good.
Test to see if either of these resolves the issue.
The problem is usually a faulty card.
J7934-69011 JetDirect 620n internal print server - 10BaseT and 100BaseTX LAN interface board - Plugs into peripheral EIO slot - Has an RJ-45 connector
Vender
http://www.dectrader.com/J6057-61001-New-HP-JetDirect-615N-internal-print-server-10Base-T-and-100Base-TX-LAN-interface-board-Plugs-into-peripheral-EIO-slot-Has-one-RJ-45-connector.html?utm_source=googlebase&utm_medium=shopping&utm_campaign=parts
image.php?type=p&id=223008&t250=y
Hope this helps helps. Please keep us updated and remember to rate this answer.
Feb 22, 2011 | HP LaserJet 4100n Printer
Error message 49 on my HP CP 2025 (printer shuts itself off and truns itself back on to see error message 49)
Firmware error:
Nov 22, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
Laser Jet 2420d. Error code 49. What is it? How do I fix it?
This is a firmware error and this error is usually caused by a bad formatter board.To troubleshoot this issue here are some steps that you can try .
3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.)
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.)
7. Remove all EIO devices from the printer. 8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
all the best
Jun 02, 2010 | HP LaserJet 2420dn Printer
A problem with HP Laserjet 2420
X PRINTER ERROR A firmware error occurred 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter. This error is usually caused by a bad formatter board.
Apr 07, 2010 | HP LaserJet 2420dn Printer
49.2F80 Service error
occurred.
Try following these steps -
memory.
turn the printer on again.
3. Go to http: www.hp.com/
support/lj2420.
Click Download Drivers and
Software
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
upgrades.
4. Try printing a job from a
different software program. If
first program and try printing a
different file. If the message
software program or print job,
for assistance.
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
printer to the network or a
computer.
2. Turn the printer off.
3. Remove all memory DIMMs
firmware DIMM in slot J1.)
4. Remove all of the
5. Turn the printer on.
6. If the error message
disappears, reinstall
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
see.
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
computer.
9. If this error message persists,
10. Replace the formatter
Jul 18, 2008 | HP LaserJet 2420dn Printer
LaserJet 2420dn Error
The error means -
occurred.
Recommended action
computer.
see.
error message.
computer.
Jun 03, 2008 | HP LaserJet 2420dn Printer
Printer Problem
error occurred
Mar 19, 2008 | Computers & Internet
HP LaserJet 4050 Printer Logo
222 people viewed this question
Ben Johnson
