Question about Whirlpool Dryers
MY CLOTHES DRYER BURNER WONT START UP - Whirlpool Dryers
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 13, 2010
Wont cycle to dry clothes
When the dryer door is open, you should be able to find a switch (it may be just a button protruding from the cabinet). The switch turns the machine off when the door is opened. It may be damaged or worn out.
Apr 04, 2014 | Maytag EPICz Electric Dryer
Dryer blows cool, not hot, air
Clean the burner exhaust and intake vents of dust and lint. Make sure the gas is turned on to the machine. Watch the burner while trying to dry clothes--the igniter should turn red, then the main valve should open to start the burner. If the plate turns red, but no fire, the control valve assembly may need to be replaced. Is the unit under warranty? If so, you may need to take advantage. Hope this helps!
Dec 24, 2009 | LG DLG5988 Gas Dryer
LG TROMM Front Load Dryer / Not drying clothes
check the vent or condensor depending on what type of dryer.
Sep 28, 2009 | Dryers
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer does not dry clothes. Flame does not stay on
run dryer for 10 minutes then remove vent hose see if start working mean flame on for while, if it is then you need to clean your vent system.
May 01, 2017 | Maytag Atlantis MDG7400AW Gas Dryer
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Burner turns off too soon. Clothes don't dry.
Most likely you have a clogged vent system that is going to the outside.try this remove the flex venting from the back of the unit and then start up the unit see if it still does it if not you wil need to clean out your venting if it still does it your cycle stat willl need to be replaced
Feb 19, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
