Question about LG KU990 Viewty
My HP IPAQ PDA has a blank screen, can any one advise how to correct the problem
  • LG Master
  • 13,433 Answers
Try reseting it
http://pocketpccentral.net/help/ipaq38xxreset.htm
That should work with pretty much all ipaqs.
Other than that possibly a mainboard problem or lcd.
Not much else I can suggest, contact your dealer or
hp for repairs incase you dont have warranty.
Posted on May 19, 2008
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
2003 model, HP iPAQ 2210 PDA. Broken screen.
A replacement screen will cost $150+. You might want to get something on Ebay, like the same model with a bad power supply, or bad hard drive, and just swap out the screen. The flat ribbon cables are critical in their placement into their sockets. Make sure the ribbons are well seated, before closing the clamps.
Sep 06, 2009 | HP Computers & Internet
Replacing a broken screen on a HP ipaq 2410
video on yube to open ipaq same kind of procedure
Mar 17, 2009 | HP iPAQ HX2490 Pocket PC
Replacing PDA Screen - HP iPAQ hx4700
http://www.repairhppda.com/video/How-to-Repair-for-HP-iPAQ-HX4700-HX4705-series.html
Jan 19, 2009 | HP iPAQ HX4700 Pocket PC
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
Pda ipaq 1710 not starting up
press the 1st and 4th button on the shortcut menu on the front and press the reset button. This will go through a complete hard reset and deactivate the battery. IT will take your PDA back to factory default mode. It saves you a lot of trouble. GOOD luck. If my explaining it to you didnt help then google "complete reset pda ipaq 1710". :)
Jul 16, 2008 | HP iPAQ RZ1710 Pocket PC
Ipaq 3115 screen
You need to open your PDA and check for a false contact between the connectors of the LCD screen and the main board.
Other cause may be that the LCD screen flat ribbon cable is defective.
Either problem requires to open the PDA to check it.
If you have experience in opening electronic devices then you can try it. Otherwise, I do recommend you to have a experienced technician in checking your PDA.
Best regards,
Apr 25, 2008 | HP iPAQ RX3115 Pocket PC
Dropped PDA
First of all, you must dissasemble the pda if you have some experience with that. There are some possible problems, one regarding the display connector to the motherboard and the other to the motherboard itself.Probably the display connector isn't atached firmly to the motherboard. There is a worse scenario where you may accidentaly burned some dc convertors on the mainboard when attemting to power on after the pda was dropped. If you can, dissasemble the pda, check the connectors, remove and reconect the back-up battery, and then, just to be shure, perform a hard reset.
Jan 11, 2007 | HP iPAQ rx1950 Pocket PC
LG KU990 Viewty Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
