Microwave Ovens Logo
Posted on Sep 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave does not heat but convection cooking works
Anonymous
Level 3:
  • Microwave Ovens Master 43,501 Answers
  • Posted on Sep 13, 2010
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10837988
Points
101584
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
I have a kenmore microwave/convection oven model 721.64289300. The microwave stopped heating up but the convection works fine. Is this repairable.
I would suspect you have a failed cook relay on the control circuit board, but that can be economically repaired.
Details are here, along with a disassembly video.
Wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
I have a KHMC106W Micro-Convect Hood - all of sudden when we used the microwave it didn't sound right and the food never heated up. I unplugged and waited about 2 min and replugged back in and it still...
the Magnetron has gone (yes it's really called that) that's the part of the microwave that emits radio waves and cooks your food... 30 years ago when this tech (Microwave cooking) was new and expensive it was cheaper to replace that part than buy new... now it's the other way around... at least you still have a working electric convection oven.
it's very rare that a Magnetron go bad, so look for an old one of the same model and use that one for parts if it's that loved.
I cleaned our oven, and now it is not heating up. The convection oven works fine, but the microwave will not heat. It comes on fine, but doesn't cook. What are the possible solutions?
Basic Microwave Oven Troubleshooting Tips
heatman101
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
1helpful
DCS - CMO24SS - 900 Watt - Microwave not Heating
If all appears to be running as its working but just no heat. Could be issue with magnetron. You could also have loose connections to magnetron or somewhere in high voltaged as well.
My sca2000bbb the convection works fine and the microwave does everything but heat up the food thanks for any help
If the microwave side is not cooking, it may be the magnetron has died, if so, it may be expensive to repair and you may have to consider another purchase.
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
