Question about E-Power Eureka E! Power Pak 2 12VDC Battery for N!ergy Tents 18 Ah Power Inverter
I used the Eureka power pak 2 to run a small fan for about half an hour one day and recharged it immediately after I was done. About a week later my power went out for about 5 hours and I wanted to use the power pak to run a lamp, and when I tried all it did was have the alarm come on. The first time I used it, you could hear the power pak turn on and run. With the second time there was nothing but the alarm, no cooling fan or anything. I followed the instruction book to the letter with no results. I plan on taking it back to the store but I though I would check online first.
Burned rice : - 1 cup of rice added 2.5 cups water, glutinous rice setting done in about 18 min. 4 hours later its all brown and in 1 solid block rock solid.
When the rice first gets done, leave it on warm for a few then unplug it. Whatever you don't eat right away put in the fridge for later.
Apr 09, 2015 | Cuckoo 10Cup IH Pressure Cooker...
How long does it take charge the sunpack 510 batt using the qbc-5
Sunpak uses different power sources on their high-power handle mount (a.k.a. hammerhead) flash guns. The most common is the battery basket that holds 4 or 6 AA or C batteries depending on the type of the unit. One can insert Nickel-Cadmium or Nickel-Metal-Hydride rechargeable batteries instead of the primary cells, this way reducing the "consumables" costs at the expense of the smaller number of flashes per battery set. (Actually, NiCd or NiMH cells would probably give smaller number of flashes compared with the alkaline cells, but the recycle time between the flashes can be shorter. The reason is that at charging the flash capacitor inside the flash current counts more than voltage. Sunpak sells Ni-Cd battery packs named CL-2 for their flashes that utilize 6 AA-cells, and CL-3 for their 622 series (4 C-cells). The charger for these is the QBC-5. It recharges the exhausted batteries in 3 hours. As a solution assuring the shortest duration between flashes Sunpak offered the Powerpak, a shoulder holster that held a dry (non-rechargeable) battery of 510V, it charged the flash capacitor directly, omitting the transistor inverter in the flash body. As such battery became obsolete, the Poverpak has been superseded with the NC510 and later the TR-II PAK, which utilizes 10 Ni-Cd rechargeable batteries as a power source, and a powerful (more capable than the one in the flash) transistor inverter. NC510 and TR-II PAK use the same connection to the flash and the same outlook as the original Powerpak but, being rechargeable, are more economical. QBC-5 also serves a charger for the NC510 and TR-II PAK. You may ask, how the same charger can be used for 4, 6 and 10 cell NiCd packs. Well, the charger is specially designed for that, although charging time differs at the different battery packs. The NC510 and the TR-II PAK needs 10 hours to be recharged, when exhausted. The best way to avoid damages (overcharging degrades NiCd and NiMH cells) is to check temperature of the batteries. Charging must be cut off if the battery becomes hotter than 45 ?C (115 ?F). If after 10 hours of charge the NC510 does not power (the otherwise working) flash, then it must be serviced. Replacing the batteries is an easy job that can be done at home, with some soldering skills; NiMH cells with solder tabs are available at many web-based supplyers. Don't solder the cells directly, heat damages them. Avoid touching parts inside, when the pack is turned on: electrocuting is fully possible. Better find a professional, if you are not familiar with the electronics.
Dec 27, 2014 | Sunpak Cameras
Gateway 6920
The dying hdd cause some problems. Replace the hdd.
Feb 21, 2014 | Computers & Internet
How long do i charge a sunpak nc 510 rechargeable using a QBC-5 CHARGER
Jan 08, 2014 | Sunpak Cameras
Microphone drains batteries even when off.
If you are using Nickel-Metal Hydride, rechargeable batteries, they are not designed to hold a charge for a week---just a couple of days if that. They are meant to be continuously charged or when charged, used immediately; best use for cameras/flash.
Nov 06, 2013 | Sennheiser Audio Players & Recorders
2002 Rav4 Battery Keeps Draining, Could this be a short?
check for bare wires starting at the battery and move toward alternator. if a bare wire touches the car body it will kill the battery. basically check whatever wires you can see. otherwise, get an obd-II tester and see what code it gives you
May 27, 2013 | Toyota RAV4 Cars & Trucks
Kenmore refr/bottom freezer has quit freezing 3 times in last 3 weeks.
If the fridge is 10yrs old or more the newer models will pay for themselves with efficiency fairly quickly. now on to the "barking" that may be the fan motor(that blows air over the condenser fins) or the compressor the later i point you to my first statement. the fan motor can be lubed with a graphite type powder on the bushings, or replaced from one of the many parts places online eg: sears parts direct, repair clinic etc. RC has videos to help with some repairs too.
Jun 24, 2012 | Refrigerators
Last summer we purchased a Friedrich Quietmaster air conditioner. It is a very large unit mounted in the wall. Almost immediately it froze up. We called the installer who notified you and you told him...
This is a social web site or forum
When you say the installer notified us
We are at home like you,we answer questions
as you can,this is not a business
I think you got the wrong site ,you had from last year
Jul 04, 2011 | Friedrich Casement SC06H10D Air...
Its hare to turn the wheel.
check check fluid level on power steering pump
Sep 19, 2009 | 1999 Dodge Grand Caravan
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
E-Power Eureka E! Power Pak 2 12VDC Battery for N!ergy Tents  18 Ah Power Inverter Logo
78 people viewed this question
Top E-Power Electronics - Others Experts
Are you an E-Power Electronics - Other Expert? Answer questions, earn points and help others
