Question about Dryers
I have a Kenmore Series 70 Dryer. It starts but runs constanly never shutting off and not getting hot. Model number 110.62702181 Serial number MM0609310 Type DWSR-ELE-2406028- FM54
  • Dryers Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 13, 2010
What size resistor does a kenmore 70 series electric dryer use....?
none that i know of.what is the model number and what is the problem you are having?there are thermostats,thermal fuses element,timer and motor.open the door.look around the opening where you put the clothes in and you'll see a tag with the model and serial numbers,just need the model,it will start with 110. or 417.
Jan 30, 2011 | Kenmore 62602 Electric Dryer
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Kenmore 70 series dryer Model 66702692
Air flow may be blocked or restricted.  Make sure the lint filter is clean and exhaust duct and outlet are not clogged.
May 30, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer 70 series flame ignites, but goes out after 5 mins
If it's gas, the coil valves get weak and are unable to hold themselves open when hot. First, check the exhaust vent. If it's clogged, it can't remove heat and it will shut off prematurely. Most likely the coil valves though.
Mar 03, 2009 | Kenmore 63942 Dryer
My kenmore 70 series dryer quick working
My wife was cleaning the top part of the dryer, and took off the knobs to clean them and the dryer will not start up and not run at all. where do I start to problem solving?
Aug 24, 2008 | Kenmore 60172 Electric Commercial Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Dryers Logo
204 people viewed this question
Top Dryers Experts
